Of course, I did send it privatezak45 wrote: Monday 16 September 2019 18:13hI, looks like problem is coming from recuring rules.
Can you send me your ics file ?
Python Plugin : iCal Multi Purpose Python Plugin for Domoticz
TheeDude
Re: Python Plugin : iCal Multi Purpose Python Plugin for Domoticz
zak45
- Domoticz version: V2024.4
New version uploaded for better management of recurring rules.
For already installed plugin, just upload the new iCal.py from dropbox and install py module recurring-ical-events.
See Wiki.
See Wiki.
ricorico94
I've been using the GCALCLI package for several years to manage my calendar and it was working well. Since this summer, I face issues to reinstall it -issues I could solve in August, nd not anymore with the latest release. So I'm looking for another solution and I saw your plugin which looks promising..
I have a couple questions on its mechanisms:
1- the wiki states that by adding :0 at end of calendar/event title, it will avoid assigning a RGB to OFF at end of event. But it's not described for SWitch. Is it the same for the SWitch ? Or any event with the :switch: setting will force the switch to OFF at end of event ? (I'd like to keep the freedom of initiating a command at beginning of an event without automatically putting to OFF at end of the event)
2- the wiki mentions a sentence I don't understand:
3- do you think it would be easy (for someone else than you) to add some other syntax or keywords, so that entries in Google calendar can follow other structure or shorter syntax, etc.. ?
4- would there be a way for a script in dzvents/lua to use your script to "scan" the various google calendar entries of a specific day and then analyse their content ? (like exporting a structured file which could be analysed by a lua script)
br,
Ricorico94
Does it mean that if I reate an event in Google calendar, then it will be reflected by the plugin into Domoticz. But if I later modify the event (or delete it) in Google Calendar, it won't be modified/deleted in Domoticz and that such later change/deletion must be done manually in domoticz ?Caution: for #cmd# keyword: plugin create automatically all the timers, but if you change or remove any entry in Calendar, you need to do that manually in your Domoticz system.
br,
Ricorico94
zak45
The same except for push (see Wiki)ricorico94 wrote: Sunday 20 October 2019 23:07 1- the wiki states that by adding :0 at end of calendar/event title, it will avoid assigning a RGB to OFF at end of event. But it's not described for SWitch. Is it the same for the SWitch ? Or any event with the :switch: setting will force the switch to OFF at end of event ? (I'd like to keep the freedom of initiating a command at beginning of an event without automatically putting to OFF at end of the event)
Right, for #cmd#, the plugin do not delete any created timers, but this can be customized if necessary...ricorico94 wrote: Sunday 20 October 2019 23:07 2- the wiki mentions a sentence I don't understand:Does it mean that if I reate an event in Google calendar, then it will be reflected by the plugin into Domoticz. But if I later modify the event (or delete it) in Google Calendar, it won't be modified/deleted in Domoticz and that such later change/deletion must be done manually in domoticz ?Caution: for #cmd# keyword: plugin create automatically all the timers, but if you change or remove any entry in Calendar, you need to do that manually in your Domoticz system.
yes, but need some basic python knowledge of course...ricorico94 wrote: Sunday 20 October 2019 23:07 3- do you think it would be easy (for someone else than you) to add some other syntax or keywords, so that entries in Google calendar can follow other structure or shorter syntax, etc.. ?
Plugin already create a structured file, It's a plain ascii text file, so you can do what you want with it.ricorico94 wrote: Sunday 20 October 2019 23:07 4- would there be a way for a script in dzvents/lua to use your script to "scan" the various google calendar entries of a specific day and then analyse their content ? (like exporting a structured file which could be analysed by a lua script)
ricorico94
HI Zak,
Thank you for your reply and explanations.
Sounds interesting indeed. I'll try downloading the scripts and see if I understand something so that I could customize for my needs.
br,
Ricorico94
br,
Ricorico94
TheeDude
Hello!
I am getting new error messages today that I haven´t seen before.
Has there been some changes?
It did only update the timer list for tomorrow, and nothing further.
I don´t know if it is because of this message or not either.
Thanks for a great program!
root@raspberrypi:/home/pi/domoticz/plugins/iCal# cat 16output.err
File "/home/pi/domoticz/plugins/iCal/iCal.py", line 1197, in <module>
processiCal()
File "/home/pi/domoticz/plugins/iCal/iCal.py", line 1049, in processiCal
startdt = startdt.astimezone(TZ)
AttributeError: 'datetime.date' object has no attribute 'astimezone'
zak45
Nothing on plugin side
Do you have updated python version !??
If possible, send me your isc file for debugging.
Lebo2d9
- Domoticz version: L stab
Hi zak45,
I have installed the iCal but i have a translation problem.
I live in Belgium (BE) dutch part.
In the iCal directory i have the translation file "en_be.lng" but in the file there are translations to Rusian.
Is there a way to get the nl translation?
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
Lebo2d9
I did a small trick to get it fixed. I "moved" my "domoticz" to the netherlands and restarted the plugin. Now all the devices are created in dutch. I also have appapted the "postalcode" to the correct one. The country code i have left on "nl"Lebo2d9 wrote: Monday 01 June 2020 14:28 Hi zak45,
Kind regards
More to come
More to come
zak45
Ok, nice to see that you have it running...
geertvercamer
- Target OS: -
I'm unable to get the devices created.
server is listening on 9003, IP is set to 192.xxx.xxx.xxx address, port is right.
Running on W10
Thanks for your help
Running on W10
zak45
be sure that no firewall is blocking.geertvercamer wrote: Friday 03 July 2020 10:48 Hi,
Running on W10
geertvercamer
- Target OS: -
I don't think so, just using Windows Firewall . It is an ip address in the local network.zak45 wrote: Friday 03 July 2020 11:09be sure that no firewall is blocking.geertvercamer wrote: Friday 03 July 2020 10:48 Hi,
Running on W10
geertvercamer
- Target OS: -
I'm also using pihole, but nothing is blocked there.geertvercamer wrote: Friday 03 July 2020 14:02I don't think so, just using Windows Firewall . It is an ip address in the local network.zak45 wrote: Friday 03 July 2020 11:09be sure that no firewall is blocking.geertvercamer wrote: Friday 03 July 2020 10:48 Hi,
Running on W10
Anyone got any ideas as why the devices are not created? (I get the popup, but they are not)
peter68
- Domoticz version: 2020.2
I have installed this plugin, webserver is running "iCal response OK!".
In the google agenda i made a appointment with the code #wrk#
However if the time is there nothing happens.
How can i see that the google agenda is loaded correctly?
The log in Domoticz shows no error
Please advise how to check where the probleme might be.
thank you!
Peter
thank you!
Peter
zak45
check domoticz device (At work) , Verify if you have corresponding schedules created.peter68 wrote: Monday 17 August 2020 14:56 Hi,
thank you!
Peter
peter68
No schedules are created. Not on the At Work switch and also not on the holiday switch.zak45 wrote: Monday 17 August 2020 15:40check domoticz device (At work) , Verify if you have corresponding schedules created.peter68 wrote: Monday 17 August 2020 14:56 Hi,
thank you!
Peter
I did find some logging in the folder /domoticz/plugin/iCal.
There is a file called 11output.err and 11output.txt
opening the 11output.err:
pi@pi2:~/domoticz/plugins/iCal $ sudo more 11output.err
processiCal()
part of the file: 11output.txt:
We beheren de werkschakelaar: kamer 1 - op het werk
start 2020-10-15 09:00:00+02:00, end 2020-10-15 17:30:00+02:00 , duration 8:30:
00 , desc
Atwork gedetecteerd: en standaardtoblank is: Yes
start 2020-10-12 08:30:00+02:00, end 2020-10-12 17:00:00+02:00 , duration 8:30:
00 , desc
start 2020-09-17 09:00:00+02:00, end 2020-09-17 17:30:00+02:00 , duration 8:30:
00 , desc
So its looks that there should be some schedules.
For my understanding. Does the plugin create schedules on the device on what time in needs to switch on/off?
thanks already.
zak45
Right.peter68 wrote: Monday 17 August 2020 16:38 So its looks that there should be some schedules.
thanks already.
peter68
I removed the plugin in hardware section of domoticz. this also removes the created devices.
Added the plugin again under a different name. New devices are created.
Also the iCal from google is downloaded. But no schedules are created under the devices. only under the seasons device are 4 schedules.
Still there a no schedules.
where to look to solve this? All help is welcome!
zak45
If possible, send me your isc file for debugging.peter68 wrote: Monday 17 August 2020 19:27
