Can somebody help my, to repair my domoticz.db ? I did try the solutions with sqlite but it result in a empty .db file.I don't know what I'm doing wrong.
Greetings,
Peter
domoticz.db corrupt Topic is solved
- waaren
Re: domoticz.db corrupt
Can you describe in more detail what you did to repair the database?Ptje wrote: Monday 17 August 2020 1:34 Can somebody help my, to repair my domoticz.db ? I did try the solutions with sqlite but it result in a empty .db file.I don't know what I'm doing wrong.
Also send you a PM
Ptje
- Domoticz version: 2020.2
Hello Waaren,
You are my hero today. The repaired db you send me, works !!! Many thanks.
Greetings,
Peter
Greetings,
Peter
- waaren
Good that it works again!
Reason the recovery failed initially was that the dump process spotted some (or an) error(s) and added "ROLLBACK;" as last line in the dump file.
To force the recovery process to load the data anyway you need to change the last line of the dump file to "COMMIT;"
You can do that with an editor or with the sed program with below command
sed -i '$ s/ROLLBACK;/COMMIT;/g' /tmp/myDump.sql # change last line in dump to prevent rollback
