Open weather map forecast Topic is solved
gtirebuyer
I set up the Open Weather Map api but when I click on FORECAST it give the forecast in Celsius instead of Fahrenheit and has a button stating "More at Dark sky". How do I get it to go to the Open Weather map site?
- kiddigital
Re: Open weather map forecast
At the moment, it doesn't! The forecast is fixed to use 'forecast.io' which is from Dark Sky (now Apple). Although the different weather modules (AccuWeather, Wunderground and Open Weather Map) do provide their own forecast URL, this URL is not used at the moment.
Maybe a good idea to create an issue on Github for this problem (and reference this forum topic). If I can find the time, I might take a look to fix this issue.
gtirebuyer
Thanks for the info. pwsweather.com has most of the local stations that used to be on Wunderground before they sold out.
- kiddigital
The PR (https://github.com/domoticz/domoticz/pull/4284) on Github now also includes 8 day weather forecast data in separate sensors.
If possible, I will see if I can create a different Forecast screen using this data in Domoticz forecast UI.
Xztraz
Great work!!kiddigital wrote: Thursday 06 August 2020 16:45 The PR (https://github.com/domoticz/domoticz/pull/4284) on Github now also includes 8 day weather forecast data in separate sensors.
That sounds awesome. or better yet. the weather tab could show a bigger forecast among the local sensors. the weather tab should be something that completely shows all things related to weather in a god overview.
is there any way of turning of history for all the bazillion sensors that is populated by ow?
