Connected Cars
mojojojo490
Re: Connected Cars
Post by mojojojo490 »
sincze wrote: Wednesday 01 April 2020 15:33
WvdM78 wrote: Wednesday 01 April 2020 14:52 Well we could have a look at it as your i3 has BMW-Connected and the data is available.
Hi sinze,
how do you get these nice pictures?
I am looking for my new Volvo V60.
Starter RPi3B, Domoticz Stable 2020.2, 10x Qubino Mini Dimmer, 1x Qubino shutter
Plugwise Anna + Adam + 2x Koen-4 & 1x Floor; SolarEdge SE3000H
Dashticz v3
FireWizard
Re: Connected Cars
Post by FireWizard »
@mojojojo490
A lot of these pictures you can find on the Internet, especially in the online brochures of the car.
Perhaps, you have to be a little creative and combine multiple picture to one that fits you.
On page 42 of the Howto, you can find that I used a single picture of my V40 for all the sensors.
See: https://github.com/FireWizard52/Volvo-o ... 0Howto.pdf
kiddigital
Re: Connected Cars
Post by kiddigital »
MrHobbes74 wrote:Hi! In the latest stable of Domoticz I have created a (c++) hardware module as native support for EV's (see https://www.domoticz.com/wiki/EVehicles). The module communicates with a car through a standard API interface, and this API can be implemented for various cars. Currently only the Tesla API is implemented, but we could also add Volvo here. It does not provide all sensors you like to have, as i see from the dashboard above, but everything can be extended of course. Is this an idea?
As a user of a connected (petrol) mercedes, I am looking at reading the data from the car into my Domoticz setup.
As there is no generic ‘connected car’ in Domoticz other than your EVehicles which support door/lid locks, odo meter, range left, etc. I am considering implementing a Mercedes Class.
But as your initial goal was EV’s, not sure if you want to go that direction? Maybe another abstraction is needed so both EV’s and petrol or others can be implemented?
Suggestions?
mojojojo490
Re: Connected Cars
FireWizard wrote: Monday 20 July 2020 21:15 On page 42 of the Howto, you can find that I used a single picture of my V40 for all the sensors.
Yeah, i saw it. Thnx.
I am trying to get the MQTT server started on my Pi 3B+.
It is a kind of troubleshooting now, but i am focused to solve it :D
Dashticz v3
FireWizard
Re: Connected Cars
https://raspberrypi.tilburgs.com/mosquitto-mqtt/
If you have specific issues, do not hesitate to ask.
JimmyH1969
Re: Connected Cars
Post by JimmyH1969 »
kiddigital wrote: Tuesday 21 July 2020 18:00
Suggestions?
I'm all in for the Mercedes Class :D
kiddigital
Re: Connected Cars
JimmyH1969 wrote: Thursday 23 July 2020 22:39
Suggestions?
See Pull Request #4281 for a beta version. Testing is appreciated :)
JimmyH1969
Re: Connected Cars
kiddigital wrote: Thursday 30 July 2020 18:57
Suggestions?
Hi, Thanks!, but I'm using Domoticz on Windows. How can i test this Pull Request?
kiddigital
Re: Connected Cars
JimmyH1969 wrote: Tuesday 18 August 2020 9:29
As this is still a PR and not yet part of the Beta, you need to build it yourself from the source repo of the Pull Request. Hopefully that is an option :)
JimmyH1969
Re: Connected Cars
kiddigital wrote: Tuesday 18 August 2020 18:12
I really have no idea how to build the Windows executable from that :D I wish....
Think i have to wait until it is available in a beta version i guess...
I also don't understand this part, can you explain a bit more maybe?
To register you own Mercedes, you have to register with your existing Mercedes Me account at 'https://developer.mercedes-benz.com/' and request access for all 5 BYOCAR API's. Each of those API's has its own scope, so within the request for an access- and refresh token, all 5 scopes have to be supplied (space separated).
Thanks, i do hope to get this working on my Windows Domoticz some day ;)
kiddigital
Re: Connected Cars
JimmyH1969 wrote: Friday 21 August 2020 17:21
@JimmyH1969, to prevent hijacking this topic; I created a new topic to further talk about the (upcoming) Mercedes Me integration.
WvdM78
Domoticz version: 2023.1
Re: Connected Cars
Post by WvdM78 »
sincze wrote: Wednesday 15 April 2020 9:19
astrapowerrr wrote: Tuesday 14 April 2020 22:16 Hmmm bmw i3 owner... im interested!!
It could be based upon bimmer_connected:
https://github.com/bimmerconnected/bimmer_connected
# get the latest version of the library
pip3 install --upgrade bimmer_connected
# run the fingerprint function
bimmerconnected fingerprint <username> <password> <region>
Now the trick would be to write a plugin that executes and retrieves the json for parsing.
Other Solution: My solution works with Pass2PHP. I could try to modify the module so you can work with that? Pass2PHP means PHP is required on your system.
I have managed to get bimmer connected (python) working on my Raspberry Pi. I can get an overview of all values. Now I am stuck how to parse these values into Domoticz. Could you give me a direction? If I have time I can share the output of bimmer connected.
sincze
Domoticz version: 2024.4
Re: Connected Cars
Post by sincze »
Are you able to use PHP ???
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
FireWizard
Re: Connected Cars
@WvdM78
As you might have read, I connected my Volvo to Domoticz.
The base was a Python script for Home Assistant, but also usable for Domoticz. The available values are published every 5 minutes to a MQTT topic.
Node Red MQTT input node has subscribed to these topics (and ignores the specific HA topics).
The various sensors, switches, etc. are converted to Domoticz Idx in Node Red and pushed to Domoticz.
This setup requires:
1, Working script.
2. Script, that pushes the output of the Python script to Domoticz, with a corresponding Cronjob
3. Working Node Red in your Local Lan
4. MQTT server in your local Lan
If you choose to follow that route, can you publish the output of your bimmer+connected sxript?
kiddigital
Re: Connected Cars
Domoticz supports python plugins in which you can read and write to (dummy) sensors.
If you ‘just’ adjust your python script to adhere to the Python plug-in structure, you should be able to get the values in Domoticz.
Other options is to code (C++) an implementation for the eVehicle framework in Domoticz, similar to the Tesla or Mercedes implementation to give Domoticz native support.
(I would not mind to give it a try, but as I do not own a BMW , I can not test it so that would make development a very cumbersome process Image)
sincze
Re: Connected Cars
Post by sincze »
Multiple ways to your goal.
I just grab the values from the JSON and use Pass2PHP as writing a python plugin takes me quite some time.
$door_lock_state 	= isset($data['attributesMap']['door_lock_state']) 		? $data['attributesMap']['door_lock_state'] : '';
$door_driver_front 	= isset($data['attributesMap']['door_passenger_front']) ? $data['attributesMap']['door_driver_front'] : '';
$door_passenger_front 	= isset($data['attributesMap']['door_passenger_front']) ? $data['attributesMap']['door_passenger_front'] : '';
$door_driver_rear 	= isset($data['attributesMap']['door_driver_rear']) 	? $data['attributesMap']['door_driver_rear'] : '';
$door_passenger_rear	= isset($data['attributesMap']['door_passenger_rear'])	? $data['attributesMap']['door_passenger_rear'] : '';
$window_driver_front	= isset($data['attributesMap']['window_driver_front'])	? $data['attributesMap']['window_driver_front'] : '';
$window_passenger_front	= isset($data['attributesMap']['window_passenger_front']) ? $data['attributesMap']['window_passenger_front'] : '';
$window_driver_rear	= isset($data['attributesMap']['window_driver_rear'])	? $data['attributesMap']['window_driver_rear'] : '';
$window_passenger_rear	= isset($data['attributesMap']['window_passenger_rear'])? $data['attributesMap']['window_passenger_rear'] : '';
$hood_state		= isset($data['attributesMap']['hood_state'])			? $data['attributesMap']['hood_state'] : '';
$trunk_state		= isset($data['attributesMap']['trunk_state'])			? $data['attributesMap']['trunk_state'] : '';
$sunroof_state		= isset($data['attributesMap']['sunroof_state'])		? $data['attributesMap']['sunroof_state'] : '';
$gps_lat            	= isset($data['attributesMap']['gps_lat']) 				? $data['attributesMap']['gps_lat'] : '';			// GPS Coordinates
$gps_lon		= isset($data['attributesMap']['gps_lng']) 				? $data['attributesMap']['gps_lng'] : '';
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Filip
Re: Connected Cars
Post by Filip »
I created an easy plugin to support the BMW Connected Drive. Currently only the mileage, but can easily be extended.
See https://github.com/FilipDem/Domoticz-BMW-plugin.
flenaers
Re: Connected Cars
Post by flenaers »
FireWizard wrote: Wednesday 27 March 2019 20:47 ...
The only command that does not work yet, is remote honk and blink. I don't use this functionality hardly, so it has very low priority for me.
I use only lock/unlock and heater on/off.
Do you still have the honk-and-blink issue?
This feature requires the user to be close to the car. The API expects the clients location in the body of the POST:
"clientAccuracy":0,
"clientLatitude":xx.xxx,
"clientLongitude":yy.yyyy
Also applies to Blink Lights and Horn.
Tested and working with PostMan.
FireWizard
Re: Connected Cars
Hi, @flenaers
Thanks for you post, however I was already aware of this.
See my posted issue at: https://github.com/molobrakos/volvooncall/issues/52 and also
https://github.com/molobrakos/volvoonca ... -392582296
I have already tried several combinations and values, but it did not work
The issue is in the VoC script of molobrakos. However he does not respond, so if you know how to solve it, would be fine.
It is not really an issue, but something nice to have.
Vondee
Re: Connected Cars
Post by Vondee »
Filip wrote: Sunday 18 October 2020 20:32 I created an easy plugin to support the BMW Connected Drive. Currently only the mileage, but can easily be extended.
Hi Filip,
I installed the plugin and works fine! I see all data from my car (BMW X-1 Hybrid) in the log files, so it would be nice to have that data also available in Domoticz!
