Blockly using Kaku Dusk Sensor
schijndela
Domoticz version: V4.10717
Post by schijndela »
Recently I Installed a KaKu Dusk sensor which I want to use between a specific time so I thought by using a Blocky script this could easily be fixed. (Unfortunately I have no knowledge of using the other scripting possiblities).
Basically I try to achieve that between 9:00 AM and 18:00 PM If the KaKu sensor is switched on then my light should be turned on for 5 minutes.
Next if the Kaku switch is off then the lights should be turned off.
But after the Sensor is activated nothing happens, I only see some error messages in the log which I can't explain, perhaps one of you can tell me what is wrong with the used script.
Many thanks for your help in advance.
Blockly script.jpg (98.86 KiB) Viewed 4597 times
Blockly error.jpg (232.31 KiB) Viewed 4597 times
Re: Blockly using Kaku Dusk Sensor
schijndela wrote: Sunday 12 July 2020 10:24 But after the Sensor is activated nothing happens, I only see some error messages in the log which I can't explain, perhaps one of you can tell me what is wrong with the used script.
You put the condition checks for state of Schemerschakelaar in the wrong blocks.
I also think the explicit switching Off is not needed as the light will already be switched Off after 5 minutes.
Try first using
and if that works try again without the elseif part.
schijndela
Hi Waaren,
Thanks for your reply, you mention that I put the check for the schemerschakelaar in the wrong Blocks, could you please explain what you mean.
Did you meant that I first need begin with time in the If statement and than end it with the Schemerschakelaar?
I modified the switching off as you suggested, so now the Blocky looks like this.
Blockly script v2.jpg (54.26 KiB) Viewed 4588 times
schijndela
I think I found the solution.
After modifying the Blockly Script and setting the time for just 1 minute for testing it worked.
Blockly script v3.jpg (48.63 KiB) Viewed 4588 times
schijndela wrote: Sunday 12 July 2020 11:49 Could you please explain what you mean.
You coded 'Schemerschakelaar = ' as one block and ' "On" and "time > 09:00 and time < 18:00" ' as another block
It should be
' Schemerschakelaar = "On" ' as one block and 'time > 09:00 and time < 18:00' as the other block
Also there are a lot of posts on this forum warning against using nested if else in Blockly.
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Are your sure this is going to work?
If (schemerschakelaar = 'On') and (Time > 9 and Time < 18)
Do schemerschakelaar = 'On' for X minutes.
When sunset is before 18 the light goes On, then it goes Off after X minutes, but will go On at the same time because schemerschakelaar is still Off.
Or am I wrong here?
schijndela
Hi Waaren,
For some reason it isn't working, the lights go on even when the schemerschakelaar is off!?
No idea how this is possible if I take a look at the log file from the schemerschakelaar it doesn't mention an entry for switching on.
Apparently there are more reason why it don't work as I hoped
For my lights I'm using a Timer which switches the lights on after sunset, My goal was to use the sunset and sunrise option in Blockly so that's why i'm using the time > 09:11 and < 18:00 option in my test.
schijndela wrote: Tuesday 14 July 2020 19:36 For some reason it isn't working, the lights go on even when the schemerschakelaar is off!?
I don't know how your current Blockly looks like so kind of hard to comment or advise
schijndela
This is how my currently Blockly looks like.
But randomly the lights go on for a minute while the switch "Schemerschakelaar" is off.
Kaku Dusk Sunrise - Sunset .jpg (48.77 KiB) Viewed 4507 times
schijndela
I modified the If statement and replaced "and" with "or" sunrise and sunset can't be a the same time.
So, with the modified statement the lights go on for one minute and than go off for one minute..
schijndela wrote: Friday 17 July 2020 19:15 This is how my currently Blockly looks like.
Nested if (else) blocks are not supported in domoticz Blockly
Treve
Domoticz version: v4.11474
Post by Treve »
Try “If time>sunrise or time<sunset and schemerschakelaar=on”
Set enz.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
schijndela
You mean like this.
Unfortunately still the same. also with this setting one minute on one minute off.
Kaku Dusk Sunrise - Sunset v2 .jpg (55.01 KiB) Viewed 4503 times
Treve
Post by Treve »
you have PB
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
schijndela
Hi All,
All my thanks go to Treve (Evert) he helped me out greatly, apparently by creating an additional Dummy switch the problem can be solved in Blockly.
I will attach a screenshot of the Blockly script which now works for me.
Next step is to fine-tune it a bit further
Blockly Dusk.jpg (42.69 KiB) Viewed 4458 times
