ADB Android TV
OedzesG
ADB Android TV
Post by OedzesG »
Hallo everyone..
for HomeAssistant there is a plugin available to get the status of Android TV.
https://www.home-assistant.io/integrations/androidtv/
Is there a possibility to get this done in Domoticz?
I use an Nvidia Shield with multiple apps and would like to know the playback status, for example to dim the lamps.
Thx in advance.
skybehind
Re: ADB Android TV
Post by skybehind »
+1
OedzesG
Re: ADB Android TV
Post by OedzesG »
+1
Until someone has arranged it (if anyone wants to build it) there is a way to send the data to Domoticz by HA using a json call.
I still had a PI somewhere and decided to test with HA this weekend. The disadvantage is that HA has to run next to Domoticz, but it works until, of course, someone makes it suitable for Domoticz.
Here is an example of how you can set this up in HA.
configuration.yaml:
media_player:
  - platform: androidtv
    host: 192.168.1.36
    adb_server_ip: 127.0.0.1
    adb_server_port: 5037
    state_detection_rules:
      'com.plexapp.android':
        - 'paused':
            'media_session_state': 3  # this indentation is important!
            'wake_lock_size': 1       # this indentation is important!
rest_command:
  shield_playing:
    url: 'http://192.168.1.11:8080/json.htm?type=command&param=switchlight&idx=63&switchcmd=On'
  shield_pause:
    url: 'http://192.168.1.11:8080/json.htm?type=command&param=switchlight&idx=63&switchcmd=Off'
automations.yaml: (testing for Netflix)
- id: '1584909354303'
  alias: 'Netflix playback: "playing" '
  description: 'Update Domoticz UV if Netflix is playing on Shield Android TV '
  trigger:
  - entity_id: media_player.nvidia_shield
    platform: state
    to: playing
  condition:
  - condition: template
    value_template: '{{ states.media_player.nvidia_shield.attributes.app_name == "Netflix"
  action:
  - data: {}
    service: rest_command.shield_playing
- id: '1584909833684'
  alias: 'Netflix playback: "paused" '
  description: 'Update Domoticz UV if Netflix is paused on Shield Android TV '
  trigger:
    platform: state
    to: paused
  condition:
  action:
  - data: {}
    service: rest_command.shield_pause
jelleeelco
Re: ADB Android TV
Post by jelleeelco »
I'm currently trying to switch the lights on/off using the Harmony-Span server, that can read the buttons pressed in an activity and update domoticz. But, within Netflix one can play/pauze using a variety of buttons (play, pauze, stop, select) so it's nearly impossible to have it work perfectly (unless ppl in the household REMEMBER that only play/pauze button will actuall trigger the ligths).
It would be great if one can read the status of the Shield directly, just as with the Kodi plugin where it reads Video / Pauze. I guess doing this via HA works for now, I just had one question if you don't mind.
Does this work for ALL the apps on the Shield, independend of what app? So i.e. Netflix, Disney, Amazon, Kodi?
Many thanks in advance,
Cheers
Jelle
lwolf
Re: ADB Android TV
Post by lwolf »
OedzesG wrote: Monday 23 March 2020 20:15 Until someone has arranged it (if anyone wants to build it) there is a way to send the data to Domoticz by HA using a json call.
Basic AndroidTV python plugin:
https://github.com/enesbcs/domo-androidtv
