Python Plugin: Domoticz-Google-Plugin
tjabas
Re: Python Plugin: Domoticz-Google-Plugin
Post by tjabas »
anyone got this plugin working?
the audio notifications works ony once.
or is there another similar working plugin?
Dnpwwo
Post by Dnpwwo »
@tjabas,
Audio works pretty well for me although because the audio is created on the internet sometimes timing is an issue.
Can you turn on debugging on the plugin and post the log?
tjabas
Post by tjabas »
thank you for your answer, i havent got the plugin installed yet, but im thinking of install it again tonight, if it looks to be the timing issue you talked about, where can i change the setting for that?
jaaap
Post by jaaap »
I got the plugin working, adding devices, and controlling volume of the casts. Very nice! However, I can't find any Play, Pause, Next buttons. Where are they located?
tjabas
Post by tjabas »
Hi!
is there a way to disable the plugin from searching for new devices?
i have a smart tv with chromecast built in, this chromecast in the tv i dont use, and the tv is only on for a couple of hours every night, the problem is that when i turn on the tv this google plugin sees the tv and ads the tv in domoticz, but when the tv is of i constantly get messages in the log that the tv is unavalible, can i disable this somehow?
tjabas
Post by tjabas »
Is there a way to change to another voice when google talks back?
i have it set to swedish, and that women sounds slightly retarded :(
Or how can i get the voice to speak English instead?
tjabas
Post by tjabas »
is it possible to add several voice/devices?
so i can get the same spoken audio notification in several other google homes?
i have tried with a speakergroup i made in the google home app, its works for a while but the volume on each device included in the group i getting lower and lower after each voice notification, very strange
DewGew
Domoticz version: V4.10618
Post by DewGew »
This plugin seems not to support Google Nest Hub:
2020-07-01 15:16:59.811 Error: (Chromecast) Unsupported device type: 'Hall', Model: 'Google Nest Hub', UUID: '2078a80e-3b4c-e1b6-547e-126d7a185f15' + IP: '192.168.2.19:8009'
DAVIZINHO
Post by DAVIZINHO »
Someone tested it on a docker container?
im trying but not discover any devices, maybe i make something wrong :-(
Flappie
Post by Flappie »
Does anybody know how to use this plugin?
I installed it, and it found my Google Home Mini.
How do i send a notification to my Home Mini with blockly? Can't get it to work.
And when i enable or disable the plugin under "Hardware", my whole Domoticz crashes....
mark.sellwood
Post by mark.sellwood »
I have the following issues with the plugin: -
When i enable or disable the plugin under "Hardware", my whole Domoticz crashes....
The plugin stops working after <24 hours, all the devices turn red
It only plays the first message then nothing
Long messages (over 5 - 6 words) are truncated, the mp3 file gets deleted while playing.
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
tjabas
Post by tjabas »
i had the same problem, mine also chrashed and the spoken audio chrashed, but after i updated domoticz to the latest stable version it suddenly worked.
mark.sellwood
I only built mine last week so I'm using the latest :-
Buster image (May 2020)
Domoticz 2020.2
Python version 3.7.3
tjabas
Post by tjabas »
mark.sellwood wrote: Tuesday 07 July 2020 12:04 I only built mine last week so I'm using the latest :-
Domoticz 2020.2
ok, then i dont know :(
tjabas
Post by tjabas »
can i deactivate the automatic discovery of new devices somehow?
tjabas
Post by tjabas »
has anyone else encountered this error in the log?
(google ) Invalid web request received, file '/home/pi/domoticz/plugins/Domoticz-Google-Plugin/Messages/4823bbe1-aaf8-3ed9-3a0b-20a7b5907208.mp3' does not exist
it has been working fine until a coulple of days ago.
DoMoAD
Post by DoMoAD »
I've got multiple nest devices in my house. I made a speakergroup in de google home app and changed the setting voice device/group to the speakergroup.
When i send a notification i only hear the message on one device. Any suggestion? I've tested the devices separatly and then they work.
update: just played spotify to the speakergroup en changed de audio. Now it also works for the domoticz notifications.
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
hey all
trawling trhough the forum i cant seem to find any examples of how to put together a dzvents script that uses the notification
i can see where everyone says use notifications, but im not sure how this si done?
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
tjabas
Post by tjabas »
sorry to say but this plugin has stopped working.
markjgabb
Post by markjgabb »
damn.... any good replacements?
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Users browsing this forum: binbo and 1 guest
