Collecting multiple scripts in a single script  [Solved]
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
Today I managed to convert a Blockly script to DzVents.
		devices = {
			'Screen deur slaapkamer 1'
	execute = function(domoticz, switch)
	    if (switch.state == 'Op' and switch.level ~= '10') then
	        domoticz.devices('Relais ^ deur slaapkamer 1').switchOn().forMin(1)
		    domoticz.devices('Relais v deur slaapkamer 1').switchOff()
	    elseif (switch.state == 'Neer' and switch.level ~= '30') then
	        domoticz.devices('Relais ^ deur slaapkamer 1').switchOff()
		    domoticz.devices('Relais v deur slaapkamer 1').switchOn().forMin(1)
		elseif (switch.state == 'Stop') then
There are multiple screens so there are also multiple Blockly scripts, which are basically the same. Only the devices listed in the script are different. I wonder if the different Blockly scripts can be collected in a single DzVents script. If so, how to start?
Thanks in advance!
Re: Collecting multiple scripts in a single script
Jan Jansen wrote: Sunday 05 July 2020 14:11 There are multiple screens so there are also multiple Blockly scripts, which are basically the same. Only the devices listed in the script are different. I wonder if the different Blockly scripts can be collected in a single DzVents script. If so, how to start?
A good start would be to show the Blockly's as the are now.
Jan Jansen
@ waaren,
Thanks you for your quick reply.
The scripts looks like:
Aantekening 2020-07-05 141552.png (111.19 KiB) Viewed 1305 times
I also use this one:
Screens master.png (86.8 KiB) Viewed 1305 times
Jan Jansen wrote: Sunday 05 July 2020 14:11 Today I managed to convert a Blockly script to DzVents.
Not sure if this is what you mean but if the only difference between the screens is the number this should do it.
return
    on =
        devices =
            'Screen deur slaapkamer*',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all ok
        marker = 'screens',
        roomNumber = switch.name:sub(-1,-1) -- get the last char of the switchname
            domoticz.devices('Relais ^ deur slaapkamer ' .. roomNumber).switchOn().forMin(1)
            domoticz.devices('Relais v deur slaapkamer ' .. roomNumber).switchOff()
            domoticz.devices('Relais ^ deur slaapkamer ' .. roomNumber).switchOff()
            domoticz.devices('Relais v deur slaapkamer ' .. roomNumber).switchOn().forMin(1)
Jan Jansen
I discovered that "switch.level ~= '10' " makes no sense. With "switch.level ~= '10' " I wanted to prevent an unnecessary next action if, for example, the 'Up' button is pressed a second time.
It can be solved with a user variable as done in the following Blockly script.
blockly screens ramen keuken.png (88.86 KiB) Viewed 1272 times
Is this possible in DzVents without a user variable?
Jan Jansen wrote: Sunday 05 July 2020 17:04 ...It can be solved with a user variable. Is this possible in dzVents without a user variable?
something like this ?
return
    on =
        devices =
            'Screens ramen keuken',
    logging =
        marker = 'screens ramen',
    execute = function(dz, item)
        local up =     dz.devices('Relais ^ ramen keuken')
        local down = dz.devices('Relais v ramen keuken')
        if item.state == 'Op' and up.state ~= 'On' then
            down.switchOff()
            up.switchOn()
            up.switchOff().afterSec(60)
        elseif item.state == 'Neer' and down.state ~= 'On' then
            up.switchOff()
            down.switchOn()
            down.switchOff().afterSec(60)
        elseif item.state == 'Stop' then
            up.switchOff()
            down.switchOff()
Jan Jansen
waaren wrote: Sunday 05 July 2020 17:28
It is not the solution I was looking for, unfortunately. Using the Blockly script (including the user variable) it works as desired. When I press the 'Up' button on the selector switch, the screen goes up. However, this only happens if the previous position of the selector switch was 'Stop' or 'Down'.
Jan Jansen wrote: Monday 06 July 2020 13:05 It is not the solution I was looking for, unfortunately.
Can you check this one?
return
    on =
        devices =
    logging =
        if item.state == 'Op' and ( up.state ~= 'On' or item.lastUpdate.secondsAgo > 59 )  then
            down.switchOff()
            up.switchOn()
        elseif item.state == 'Neer' and ( down.state ~= 'On' or item.lastUpdate.secondsAgo > 59 ) then
            up.switchOff()
            down.switchOn()
            up.switchOff()
            down.switchOff()
Jan Jansen
waaren wrote: Monday 06 July 2020 13:21 Can you check this one?
First thank you for your time and attention!
The last script doesn't do what I want either. When I press the 'Neer' button, 'Relais v ramen keuken' is activated. For example, if I press the same button again after 5 minutes, 'Relais v ramen keuken' will be activated again. I do not want that relay to be reactivated when pressing the 'Neer' button again.
Jan Jansen wrote: Monday 06 July 2020 14:53 The last script doesn't do what I want either. When I press the 'Neer' button, 'Relais v ramen keuken' is activated. For example, if I press the same button again after 5 minutes, 'Relais v ramen keuken' will be activated again. I do not want that relay to be reactivated when pressing the 'Neer' button again.
If I understand correctly what you want I don't think it is possible without saving the last action in some way. Below script does that using dzVents persistent data.
return
    on =
        devices =
    logging =
    data =
        screenState = { initial = '' },
        if item.state == 'Op' and dz.data.screenState ~= 'Up' then
            dz.log('Going up',dz.LOG_DEBUG)
            down.switchOff()
            up.cancelQueuedCommands()
            up.switchOn()
            dz.data.screenState = 'Up'
        elseif item.state == 'Neer' and dz.data.screenState ~= 'Down' then
            dz.log('Going down',dz.LOG_DEBUG)up.switchOff()
            down.cancelQueuedCommands()
            down.switchOn()
            dz.data.screenState = 'Down'
        elseif item.state == 'Stop' and dz.data.screenState ~= 'Stop' then
            dz.log('Stop',dz.LOG_DEBUG)
            up.switchOff()
            down.switchOff()
            dz.data.screenState = 'Stop'
            dz.log('nothing to do ',dz.LOG_DEBUG)
Jan Jansen
Re: Collecting multiple scripts in a single script  [Solved]
@ waaren,
Now it works as desired, thanks a lot!
regards.
