Get Chinese rim lock working with Domoticz
hvds
Post by hvds »
Hi All,
I purchased a H206D *smart lock* rim lock on 433 MHz on AliExpress (https://nl.aliexpress.com/item/32960417617.html).
2 Remote controls were included.
Unfortunately I can't learn the code from the remote control. I enabled all protocols in Domoticz but at no result.
Can anybody point me into the right direction?
Henk
cogliostrio
Re: Get Chinese smart lock working with Domoticz
Post by cogliostrio »
What are you enabeling in domoticz? RFXCom?
Is it listed as supported with the 433MHz receiver you are using?
It is likely that is using a some sort of roling security code which cant be connected to.
hvds
Post by hvds »
I use Rfxcom.
It is not listed as supported, but I hoped that there should be a method to get this working.
hvds
Re: Get Chinese rim lock working with Domoticz
Post by hvds »
I initially posted this as a smart lock. Actually it is a rim lock which locks and unlock on 433 MHz hand transmitters.
Does that make any difference?
If I am unable to capture and resend the code of these transmitters, than I have to connect a PiFace to my Raspberry Pi to control this transmitter. Pretty dirty solution in my opinion :)
