How to override a scene timer?
JeroenG
Domoticz version: 20231
Post by JeroenG »
I have a scene which switches off all the lights around 23:30 (working fine).
But sometimes I want to stay watching a movie or and prevent the lights from switching off. I made a dummy switch to override the automatic execution of the scene, but my script is not working, it fails on the if statement but I don't see the error :( .
		scenes = {
			'Test scene'
    execute = function(domoticz, scene)
	if domoticz.device.('Niet naar bed').status == 'Off'
	then
		domoticz.log('Scene ' .. scene.name .. ' was switched off', domoticz.LOG_INFO)
	 	domoticz.log('Scene ' .. scene.name .. ' was blocked', domoticz.LOG_INFO)
Thanks a lot!
Jeroen
Treve
Domoticz version: v4.11474
Re: How to override a scene timer?
Post by Treve »
I have the same condition now working for a few years and solved it with a simple blockly.
-Make a dummy switch ‘override’
-Make a device ping (ping the television)
-Make a if-then blockly
This will only work of course if the television has a Ethernet connection.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
JeroenG wrote: Tuesday 16 June 2020 23:06 I have a scene which switches off all the lights around 23:30 (working fine).
To correct the syntax you can do like below. But it will not block the automatic switch of the scene. I don't know of a way to block a timer with a script.
return
    on =
        scenes =
            'Test scene',
        if domoticz.device.('Niet naar bed').status == 'Off' then
MartinManders
Domoticz version: 2023.2
Post by MartinManders »
Hey,
Maybe the best solution is to make the timer part of your script?
If triggered by timer AND not ‘Niet naar bed’ then Switch off, else do nothing....
- Reliability means:
never have to say i am sorry -
Rpi's 3B 1x RFX com + 20 dev 1x ZWave + 130 dev + rpi 4 remote
Users browsing this forum: Wiers and 1 guest
