Domoticz does not see device in Aeotec Z-stick
Marnix
Post by Marnix »
Dear all,
My setup is a Windows 10 system, an Aeotec Z-stick Gen5 and one Fibaro wall plug.
The issue I have is that Domoticz does not “see” the wall plug.
Here’s the chain of actions that I did:
1. Added the wall plug to the Z-stick (press button on Z-stick until blue ring flashes, then press button on wall plug 3 times);
2. Installed Domoticz on Windows 10;
3. installed the drivers for the Z-stick;
4. As per the Domotics Wiki, installed a 32 bits Python;
5. Added the Z-stick under the Hardware menu in Domoticz as “Comm5 MA-4XXX/MI-XXXX Serial/USB interface”
Now, when I start Domoticz, as far as I can see in the log everything is fine (there are no errors):
2020-06-13 17:15:26.733 Active notification Subsystems: fcm, http (2/13)
2020-06-13 17:15:26.733 Starting shared server on: :::6144
2020-06-13 17:15:26.420 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-06-13 17:15:26.436 Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2020-06-13 17:15:26.436 Status: Startup Path: D:\Program files\Domoticz\Domoticz\
2020-06-13 17:15:26.717 Status: PluginSystem: Started, Python version '3.5.2'.
2020-06-13 17:15:26.733 Status: WebServer(HTTP) started on address: :: with port 8080
2020-06-13 17:15:26.733 Status: WebServer(SSL) started on address: :: with port 443
2020-06-13 17:15:26.733 Status: TCPServer: shared server started...
2020-06-13 17:15:26.733 Status: RxQueue: queue worker started...
2020-06-13 17:15:28.792 Status: Comm5: Worker started...
2020-06-13 17:15:28.802 Status: NotificationSystem: thread started...
2020-06-13 17:15:28.802 Status: EventSystem: reset all events...
2020-06-13 17:15:28.817 Status: EventSystem: reset all device statuses...
2020-06-13 17:15:28.862 Status: Python EventSystem: Initalizing event module.
2020-06-13 17:15:28.862 Status: EventSystem: Started
2020-06-13 17:15:28.862 Status: EventSystem: Queue thread started...
2020-06-13 17:15:29.062 Status: PluginSystem: Entering work loop.
2020-06-13 17:15:30.206 Status: Incoming connection from: 127.0.0.1
But there are no devices in the devices menu. Actually, I expected that the Z-stick would tell Domoticz that it knows the Fibaro wall plug?
What puzzles me is that when I press the button on the wall plug, there’s a lot of framing errors added to the log. I tested several times and the framing errors are a direct result of pressing the button on the wall plug.
2020-06-13 17:23:23.637 Error: Comm5: Framing error
2020-06-13 17:23:23.638 Error: Comm5: Framing error
2020-06-13 17:23:25.123 Error: Comm5: Framing error
2020-06-13 17:23:26.641 Error: Comm5: Framing error
2020-06-13 17:23:28.141 Error: Comm5: Framing error
I tried the learn Light/Switch from the Switches menu, but as soon as I press the button on the wall plug, I get the framing error again.
I searched the forum and I found posts about including nodes and node management. E.g. “Setup=>Hardware=Z-Wave-Setup=>Node-Management=>Include Node”, but I don’t see these menu options in my Domiticz installation.
I don’t know what else to try. I hope that someone can help me out here.
Thanks for reading this.
Bigted
Domoticz version: 2020.1
Re: Domoticz does not see device in Aeotec Z-stick
Post by Bigted »
Under Settings | Hardware do you have a device OpenZWave USB with a setup button next to it, if yes then click on Setup, Node Management top right and select Include Node and pair the wall plug
Marnix
Post by Marnix »
Thank you very much, Bigted. I selected the wrong hardware type. With OpenZWave USB It sees the wall plug and the Z-stick:
http://www.dropbox.com/s/2bhfxm84eu5fml ... e.JPG?dl=0
But now I have a follow up question. After adding the node, I get six new devices:
http://www.dropbox.com/s/ju4p4mgn5hs5pa ... s.JPG?dl=0
idx = 1 is the plug, clicking the light bulb turns it on and off.
I know the plug monitors the power, so I can explain idx 5 and idx 2. But what are the other 3, "previous event cleared" and unknown?
Any idea?
Thanks again for your help.
