Strange things with temp. block Topic is solved
- EdwinK
- Domoticz version: BETA
Re-added my temperature meter again, and hen I just use the block, 557 in this case, I get 3 buttons (temp, humidity and a 3rd one). So I thought I could split them with '557_1','557_2','557_3'). But then the last button isn't showing. See attachment.
The device is a Cresta, TFA TS34C temp/humidity sensor
Lokonli
Re: Strange things with temp. block
Subdevice 3 is reserved for Barometer. The dewpoint is subdevice 4, so try with '557_4'
- gielie
- Domoticz version: latest β
I had somewhat the same thing only I use the combine option and now I get the dew point as extra in my block while I only want the temp and moisture percentage in 1 block. Is this still possible in some way?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Lokonli
Of coursegielie wrote: Tuesday 09 June 2020 16:13 I had somewhat the same thing only I use the combine option and now I get the dew point as extra in my block while I only want the temp and moisture percentage in 1 block. Is this still possible in some way?
You can use the 'value' parameter.
As an example, if device 16 is your temp device, define your block as follows:
blocks['16_1'] = {
value: '<Temp>°C, <Humidity>%',
unit: '',
- EdwinK
Didn't know that. Thought it was just numbering upwards.Lokonli wrote: Tuesday 09 June 2020 16:03 Subdevice 3 is reserved for Barometer. The dewpoint is subdevice 4, so try with '557_4'
Opus
For me, only the wind strength and direction are shown. I cannot reach the other parameters with a sub IDX. I also need gust and temperature.
Or I overlook something there?
The given string is: 225.00; SW; 4; 8; 17.6; 17.6 I need the 4th and 5th value.
Lokonli
It seems that the Dashticz wind block only shows strength and direction, and that this is hard coded. It makes it a bit more difficult to improve.Opus wrote: Tuesday 16 June 2020 15:19 For me, only the wind strength and direction are shown. I cannot reach the other parameters with a sub IDX. I also need gust and temperature.
It would be better to change this into a generic block, like the other Domoticz devices.
I'll add this to the feature request list.
webrazor
I also have some strange things only with the temp. block.
After i upgraded to 3.5 some .css settings are not working anymore for the temp. block but still work for other blocks.
For example font size of the value and border margin for other blocks still works but not for temp. block.
Lokonli
Maybe this post contains your answer:webrazor wrote: Monday 20 July 2020 10:57 I also have some strange things only with the temp. block.
https://www.domoticz.com/forum/viewtopi ... 73#p253673
if not, let me know.
