currently i'm using an impuls switch (type on/off) with a relais connected to the switch. I made a dummy switch (type push on button) with a block-script that switches the impuls switch "on" and after 1 second "off".
I also connected a contact sensor to the door so i can see if the door is open or closed.
Is there a smarter way to do this? I would like to combine those three switches to one. Is that posible??
and last but not least: Is it posible to present these switches as one garage door in Home Bridge for the use with home kit?
Thnx for the help!
garage door opener with switch+relais and contact sensor and use in homebridge
anp21
Re: garage door opener with switch+relais and contact sensor and use in homebridge
This is what I am using after several unsuccessful attempts to pair GD00Z-1. I use Conbee2 and Deconz.
1.Sonoff SNZB-04 Door sensor -replace magnetic sensor with tilt sensor;
2.Tuya WHD02 Mini Smart Switch - modify relay output, you have to isolate the contacts;
3. Use Zigbee 3 Gang Remote and Lua script
If anyone is interested, I can post more info
Hi anp21!!!anp21 wrote: Thursday 05 August 2021 21:17 This is what I am using after several unsuccessful attempts to pair GD00Z-1. I use Conbee2 and Deconz.
¿how did you do to modify WHD02 to convert it in dry relay?
Thanks in advance!!
anp21
Sorry for the delay, attached is zip file with all pictures. Also you can use no-name Zigbee switch, much easier to modify![Image]()
- 20220406_104409-600.jpg (23.52 KiB) Viewed 589 times
- 20220406_104535-600.jpg (29.79 KiB) Viewed 589 times
- Garage opener1.zip
- (320.67 KiB) Downloaded 38 times
