calculation  [Solved]
elbennito
calculation
Post by elbennito »
help:
I Have a chlorine sensor connected to domoticz. (this is a analog sensor)
name in domoticz: chloor.
I want to make a calculation with the value (devide by 1.4)
That value should then update a dummy sensor named: chloorcal
this is what I have now. But it doesnt work. Any idea anybody?
        timer = {
           'every 1 minutes'
    execute = function(domoticz, device, timer)
        local chloorcal  = domoticz.devices('chloorcal')
        local chloor  = domoticz.devices('chloor')
        local factor = 1.4
        local chloorcal = tonumber(domoticz.utils.round (chloor / factor) )
          chloorcal.updateCustomSensor(chloorcal)
elbennito
Re: calculation
Post by elbennito »
update, but still not working
CODE: SELECT ALL
        timer = {
           'every 1 minutes'
        local chloor  = domoticz.devices('chloor').value
        local factor = 1.4
Re: calculation
elbennito wrote: Friday 05 June 2020 13:40 update, but still not working
value is not one of the attributes of a device. So in your script it will always be nil.
What type / subtype is your chloor device (as seen on the devices tab)?
What is your domoticz / dzVents version?
When debugging a script it helps to add some logging.
Below script might show some useful information in the log
return
    on =
        timer =
           'every 1 minutes',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'Chloor',
    execute = function(domoticz)
        domoticz.log('deviceType chloor: ' .. chloor.deviceType,domoticz.LOG_DEBUG)
        domoticz.log('deviceSubType chloor: ' .. chloor.deviceSubType,domoticz.LOG_DEBUG)
        domoticz.log('nValue chloor: ' .. chloor.nValue,domoticz.LOG_DEBUG)
        domoticz.log('sValue chloor: ' .. chloor.sValue,domoticz.LOG_DEBUG)
        local factor = 1.4
        --local chloorcal = tonumber(domoticz.utils.round (chloor / factor) )
        --chloorcal.updateCustomSensor(chloorcal)
elbennito
Re: calculation  [Solved]
Post by elbennito »
i ended up using the multipliers on my analog inputboard to do the calculation.
