FAKRO : stop command while closing doesn't work
keros
Post by keros »
Hello every body,
I have installed two roof windows from Fakro (FTU-V Z-Wave) with a blind (ARZ Z-WAVE). The windows and the blinds are motorized and it uses Zwave to communicate : that great (compaired to Velux)
The little disadvantages is that if I open the windows while the blind are closed -> I brake it ! (it only admit an openning of 20 cm).
I wanted to use Domoticz to avoid this problem. My idea was to use the dzvents .stop() function.
I tried the folowing scenarios :
  • Windows closed : command Stop sent > Nothing happen (that normal) :)
  • Windows opening : command Stop sent > the windows stops where it is (that what I want) :D
  • Windows opened : command Stop sent > the windows starts to close :(
  • Windows closing : command Stop sent > the windows continues to close :o
My Zwave Stick is a AEON Labs ZW090 Z-Stick Gen5 EU.
The command while opening or closing should have the same effect :roll:
I have the same problem on the two windows and the two blinds.
Does anyone have some Fakro devices ?
Thanks for you're help.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
keros
Re: FAKRO : stop command while closing doesn't work
Post by keros »
The device is not reconized in the Zwaves device list.
Is there a link with my problem ?
rapscallion42
Domoticz version: 2025.2
Post by rapscallion42 »
Hi You have to do the opposite command.
a) when the window is closed and you send an open command, you can stop it somewhere by sending a close command.
b) when the window is open and you send a close command, they will begin to close. if you want it to stop somewhere before they are fully closed, then send an open command.
keros
Post by keros »
Thanks for your reply.
The idea was to make a script which would protect the blind form an inapropriate movement of the windows even. For example, if I use the remote or the button, I don't know the windows moves : i can't send the opposite command.
