Hi ,
I have 2 scripts of two lamps.
The first one is called: Tuinlamp_voor and this is working fine (Tuinlamp_voor_OK.png)
The second one is called: Buitenlamp_voor and this one does not work at all. (Buitenlamp_voor_NOK.png)
Both scripts are exactly the same .
There is only 1 difference.
In the first script the end time is 23:59
and in the second script the endtime is 05:00
I can not figure out why the first one runs very good and why the second one does not even start and so does nothing at all
Can somebody help me with this ??
Thanks in advance,
Rick
Why does one script not work while they are almost exactly the same?? Topic is solved
rick8245
- Buitenlamp_voor_NOK.png (16.54 KiB) Viewed 1707 times
- Tuinlamp_voor_OK.png (12.19 KiB) Viewed 1707 times
BoelShit
Re: Why does one script not work while they are almost exactly the same??
If you look at the "Buitenlamp_voor" the sunset time is always after the 5:00 time as well. So it will turn on your light and immediately turn off due to the Else if. Your assumption is that the 5:00 is for the next day but it's also applicable for the same day
jkimmel
- Domoticz version: 2021.1
Try
because time after sunset is > 05:00
I was a bit late
I was a bit late
Rfxcom
Raspi 4
Raspi 4
rick8245
Thanks guys,
I will try this.
And keep you updated
I will try this.
MikeF
- Domoticz version: V2022.2
I think you mean:
(or rather than and)
- waaren
I guess you need both..
rick8245
Guys,
thanks for the scripts.
I tried them both and the script of Waaren works exactly like I want.
Thanks also to Jkimmel and MikeF.
Regards,
Rick
Regards,
Rick
