Listen to your favourite radios V2
Bospieper
Domoticz version: 2026.3
Re: Listen to your favourite radios V2
Post by Bospieper »
Hi, I hope you can help with streaming radio.
I followed the steps in your guide (see pictures attached). For the record I have only one station selected in your software just to try if it works.
The problem is that when I connect my soundbox by bluetooth to the Pi it tells me to change the output device in the player menu. So you can see on the pictures attached there is much choice in selecting a output device. When I select Bluetooth as a output device I get a failure with the message that the output device is not recognized.
I don't know where to look for.
I have a Raspbery Pi 3+ with Buster
Domoticz version 2020.2
Output device.JPG (58.55 KiB) Viewed 2164 times
Audio device.JPG (115.69 KiB) Viewed 2164 times
0n370uch
Domoticz version: Latest
Post by 0n370uch »
Hi, oh good question. Did you tried the configuration via terminal?
Bospieper
Post by Bospieper »
Yes I did, no sound was heard.
The system is telling me to choose a device for audio output. My BT speaker is showing in a list of devices bud I cannot select it.
See attachmend.
Select a device.JPG (18.16 KiB) Viewed 2157 times
0n370uch
Post by 0n370uch »
Sorry I don't know... never used the GUI.
Bospieper
Post by Bospieper »
This is the terminal which comes with Domoticz.
Mayby you can tell me how to with terminal commands
My BT Speaker is automaticaly connected by the cron job as discribed.
0n370uch
Post by 0n370uch »
Bospieper
Post by Bospieper »
Oke thanx, the most part I did already. Question do I also need the /etc/asound.conf file because I already have a ~/.asoundrc.cfg file?
joshu
Post by joshu »
Based on this thread I created a solution which may also be helpful.
Please have a look at https://github.com/joshuisken/domoradio
0n370uch
Post by 0n370uch »
joshu wrote: Monday 28 February 2022 10:30 Based on this thread I created a solution which may also be helpful.
Great. Thank you.
