Listen to your favourite radios V2
- Bospieper
- Domoticz version: 2026.3
Re: Listen to your favourite radios V2
Hi, I hope you can help with streaming radio.
I followed the steps in your guide (see pictures attached). For the record I have only one station selected in your software just to try if it works.
The problem is that when I connect my soundbox by bluetooth to the Pi it tells me to change the output device in the player menu. So you can see on the pictures attached there is much choice in selecting a output device. When I select Bluetooth as a output device I get a failure with the message that the output device is not recognized.
I don't know where to look for.
I have a Raspbery Pi 3+ with Buster
Domoticz version 2020.2
- Output device.JPG (58.55 KiB) Viewed 2144 times
- Audio device.JPG (115.69 KiB) Viewed 2144 times
0n370uch
- Domoticz version: Latest
Hi, oh good question. Did you tried the configuration via terminal?
- Bospieper
Yes I did, no sound was heard.
The system is telling me to choose a device for audio output. My BT speaker is showing in a list of devices bud I cannot select it.
See attachmend.
See attachmend.
- Select a device.JPG (18.16 KiB) Viewed 2137 times
0n370uch
Sorry I don't know... never used the GUI.
- Bospieper
This is the terminal which comes with Domoticz.
Mayby you can tell me how to with terminal commands
My BT Speaker is automaticaly connected by the cron job as discribed.
0n370uch
Here is everything you need:
https://www.domoticz.com/forum/viewtopi ... 20#p191403
- Bospieper
Oke thanx, the most part I did already. Question do I also need the /etc/asound.conf file because I already have a ~/.asoundrc.cfg file?
joshu
Based on this thread I created a solution which may also be helpful.
Please have a look at https://github.com/joshuisken/domoradio
0n370uch
Great. Thank you.joshu wrote: Monday 28 February 2022 10:30 Based on this thread I created a solution which may also be helpful.
