Event triggering
jwilmes
Event triggering
Post by jwilmes »
I have a blockly using 2 conditions:
- a switch condition
- a time condition.
- trigger on switch (not all to avoid too many checks)
If switch is on and time > 22:00 the action should start
This event does not trigger. Can't figure out why
AllesVanZelf
Domoticz version: 12467
Re: Event triggering
Post by AllesVanZelf »
Are you sure that deur bijkeuken is open is the right trigger? Should it not be On of Off?
wouterlet
Post by wouterlet »
It's good to check the right state indeed. Next to that you're time locks should be with an and I guess. Because now one of them is always true.
AllesVanZelf
@Wouterlet, Time can never be > then Sunset And < then Sunrise. That will never happen. Because > sunset is from sunset till 0:00 and before sunset is from 0;00 till sunrise. If I'm not mistaken. So OR is okay here.
wouterlet
Post by wouterlet »
I'm sorry you're right. I switched them around. That part must be fine
