PIR status not resetting
Dave21w
Domoticz version: Stable
Post by Dave21w »
I have PIR connected via and RFXCom, it is seen as a PT2262 device and only sends an ON signal, I have added it as PIR and set the off delay to 5 secs, each time it is triggered you can see the "last seen" time update and then 5 seconds later it updates again because it has been reset to off I assume because of this setting :-
Off Delay: 5 (Seconds) 0 = Use sensor time
However the PIR shows as permanently on according to the device unless I manually refresh the webpage, if the time can be seen to update without a page refresh why does the device status not change as well, is this normal?
TIA
Geitje
Re: PIR status not resetting
Post by Geitje »
You mean it only switches back to off when you manually refresh the webpage? What browser do you use? In Chrome my motions sensors switch back off without refreshing.
Zwave, Zigate, RFlink etc.
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
It probably creates two devices. One device for ON and one device for OFF.
Create another dummy device to hold the actual status, and control it from LUA.
for deviceName,deviceValue in pairs(devicechanged) do
    if (deviceName=='Kerui 01 Open') then
        commandArray[#commandArray + 1] = {['Kerui 01 Contact'] = 'On'}
    if (deviceName=='Kerui 01 Closed') then
        commandArray[#commandArray + 1] = {['Kerui 01 Contact'] = 'Off'}
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
Dave21w
Post by Dave21w »
Yes it only switches back to off if i refresh the page however this is when i use and RFXCom to recieve the signal, if I do the same thing with an RFLink the status changes as it should. In fact if I use both recievers at the same time and create 2 devices (one for each) and have them next to each other on the switches tab one resets and the other doesn't even though they are both setup exactly the same including the Off delay in the settings :-
The sensor does not send an off, it is only detected as one device and just sends an ON so a reset in domoticz back to OFF is essential.
Sorry for the delay in replying, thought I'd put my question in another section.
Geitje
Post by Geitje »
That is strange. Seems related to RFXcom then?
Then I would use the RFlink ;)
You could bypass this by creating a separate event (blocky for example) which: If: on -> switch sensor of after 3 seconds. Kind of dirty way....
