Scraping only the temperature from WeatherUnderground sensor
ThinkPad
Post by ThinkPad »
I would like to use the outside temperature i get from wunderground in an event. However, the data from Wunderground is all put in one single device. See screenshot below.
Above are virtual devices i got when i added the wunderground hardware.
I tried 3 different stations in my neighborhood, but they all put the data in one device like this.
How can i get outside temperature in one device?
Last edited by ThinkPad on Wednesday 14 January 2015 22:04, edited 2 times in total.
Reason: Made title more clear
jackslayter
Domoticz version: stable
Re: Use only variable from wunderground device
Post by jackslayter »
add the first line to device
create new virtual temperature sensor
create new lua script
--script_device_tempWU.lua
local sensorwu = 'sensor' --sensor of wunderground
local tempsensor = 'temp' --virtual temp sensor of wunderground
local idx = 68 --idx of your virtual temp sensor of wunderground
if (otherdevices_lastupdate[sensorwu]) then
sWeatherTemp, sWeatherHumidity, sWeatherPressure = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)")
sWeatherTemp = tonumber(sWeatherTemp)
commandArray['UpdateDevice'] = idx .. '|0|' .. tostring(sWeatherTemp)
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
ThinkPad
Post by ThinkPad »
Hey thanks!
But can you help me a little bit more?
I found out how to create a virtual temp sensor:
/json.htm?type=createvirtualsensor&idx=XX&sensortype=80
(XX is the IDX i have chosen, looked what the current highest IDX was and did that +1) 80 stands for temperature only.
But what to do now? I put the script in /home/pi/domoticz/scripts/lua/. I put in the IDX.
Do i need to change anything else? ('sensorwu' and 'tempsensor' ?)
And what do you mean by: "add the first line to device" ?
jackslayter
ThinkPad wrote:Hey thanks!
I never used that
ThinkPad wrote:But what to do now? I put the script in /home/pi/domoticz/scripts/lua/. I put in the IDX.
Yes
No
Add the line: 44 wunderground 0001 ...... in your device list (green arrow)
ThinkPad
Post by ThinkPad »
I am sorry but i don't understand how to get it working. Can you please explain a little bit more?
How do you created a virtual sensor?
And you say: 'add the first line to device'. But i really don't understand that part. Which first line, and to which device, and mostly: HOW? :p
jackslayter
the arrow will be blue
if green click on to add device
ThinkPad
Post by ThinkPad »
Together with someone from a Dutch IT forum i figured it out. I also added it to the wiki to help others:
http://www.domoticz.com/wiki/Virtual_we ... emperature
ThinkPad
Post by ThinkPad »
User 'nickyb2' did a few small modifications to the script, so it now runs as soon as the sensor from WU is updated. This instead of the version i had before, where it would run every 10 minutes. In the worst case the script could lag behind so the data in the virtual_temp sensor would be 19 minutes old. It is now instaneously updated as soon as the WU sensor is updated.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
ThinkPad wrote:User 'nickyb2' did a few small modifications to the script, so it now runs as soon as the sensor from WU is updated. This instead of the version i had before, where it would run every 10 minutes. In the worst case the script could lag behind so the data in the virtual_temp sensor would be 19 minutes old. It is now instaneously updated as soon as the WU sensor is updated.
It's still not very clear what to put in the "sensorwu"
idx, id, hardware or name?
No matter what i put in my virtual sensor isn't updated.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Siewert308SW
Re: Scraping only the temperature from WeatherUnderground se
Got it working but not by the WiKi.
Something is missing the script or something else is going on.
This is what i've done.
Added WeatherUnderground as my virtual Weatherstation per wiki.
Added the WeatherUnderground device with the ID 0001 under the unused devices list and called it WeatherUnderground
Then i got to Setup --> Hardware, and created new virtual hardware and called it "Buiten Temperatuur". (Outside Temperature)
Then i clicked 'Create virtual sensor' and created a sensor with type 'Temperature'.
Then i got to Setup --> Devices and added the new "Buiten Temperatuur" virtual device to Domo and looked up the Device ID in the devices menu
This is all according the WiKi.
But now the LUA script
When i use the LUA script in the WiKi it doesn't work and the new virtual "Buiten Temperatuur" device isn't updated.
Did some searching and some copy and past en the final script below does work.
local sensorwu = 'WeatherUnderground' --Original sensor of wunderground carrying the 0001 ID
local tempsensor = 'temp' --virtual temp sensor of wunderground (don't touch)
local idx = 157 --idx of your manual created virtual temp sensor
if devicechanged[sensorwu] then
Setup:
- DS923+ Docker
ThinkPad
Post by ThinkPad »
That's weird, as it is working fine here.
script_device_sensorWU.lua
local sensorwu = 'Buitentemperatuur' --sensor from wunderground
local idx = 102 --idx of your virtual temp sensor of wunderground
'Buitentemperatuur' is the device that is added when you configure WU. This is the device that contains multiple values, like temperature, pressure, humidity etc.
IDX 102 is a virtual temperature sensor i created.
I have 'script_device_sensorWU.lua' in /home/pi/domoticz/scripts/lua.
I uploaded the script contents again to the wiki, maybe there was a typo in it.
D'rMorris
Post by D'rMorris »
Also check this wiki page.
myozone
Post by myozone »
This is what I have and it doesn't work ...
local sensorwu = 'wx' --name of the sensor that gets created when you add the WU device (and that contains multiple values like temperature, humidity, barometer etc)
local idx = 21 --idx of the virtual temperature sensor you created above
	commandArray['newtemp'] = idx .. '|27|' .. tostring(sWeatherTemp)
domo test.jpg (170.74 KiB) Viewed 13902 times
ThinkPad
Post by ThinkPad »
Change
local idx = 21
in the script from 21 to 27 and see if it works.
myozone
Post by myozone »
Thank you for the prompt reply! changed it - still not working...
ThinkPad
Post by ThinkPad »
Hmmm :(
I don't know, i compared my WU device and virtual sensor device to yours, and look identical.
Maybe try copying my script again:
Above code is directly pulled from my working setup, so nothing edited/modified.
myozone
Post by myozone »
The only major difference is your line:
and mine is
ThinkPad
Post by ThinkPad »
Ok, but why?
Just try my script and see if it works. I don't understand where your modification is needed for :mrgreen:
myozone
Post by myozone »
One other thing, I have mine running on a Windows 7 machine. The script is executing though - showing in the log.
myozone
Post by myozone »
Got it working now ! :D - Thanks for your help. change the line
I thought the script worked like that !
