OFF
/json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=0
ON
/json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=1
OFF
ON
If you don't want to trigger the event system when sending this command you need to adddjdevil wrote: Tuesday 19 May 2020 12:56 I used this code for On and Off a switch without trigger event but from the new version Version: 2020.2 Build Hash: b63341bc0 seems to activate the trigger and then activate the dzvents script connected to the key.
&parsetrigger=false
OFF
/json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=0&parsetrigger=false
ON
/json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=1&parsetrigger=false
Perfect it works, I wasn't aware of it thank you very muchwaaren wrote: Tuesday 19 May 2020 14:45If you don't want to trigger the event system when sending this command you need to adddjdevil wrote: Tuesday 19 May 2020 12:56 I used this code for On and Off a switch without trigger event but from the new version Version: 2020.2 Build Hash: b63341bc0 seems to activate the trigger and then activate the dzvents script connected to the key.
So the complete JSON's becomeCode: Select all
&parsetrigger=false
This option was added in version V4.11656 and since then the default behavior for calls with param=udevice changed.Code: Select all
OFF /json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=0&parsetrigger=false ON /json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=1&parsetrigger=false
Does it work also for commands like&parsetrigger=false
/json.htm?type=command¶m=switchlight&idx=<IDX>&switchcmd=Toggle
Nohestia wrote: Wednesday 20 May 2020 22:32Does it work also for commands like&parsetrigger=falseCode: Select all
As already mentioned in the wiki:Hencor wrote: Wednesday 16 February 2022 10:31 In my validation it turns out that &parsetrigger=false doesn't apply to the action set in the selector switch settings. Am I right or I'm doing something wrong?
My attempt: /json.htm?type=command¶m=switchlight&idx=IDX&switchcmd=Set%20Level&level=LEVEL&parsetrigger=false
So my goal is that the selector switch action is only triggered when the user push the button on the interface and not triggered when the status is changed via json. Is there another possiblity without dzvents scripting?
