Unable to Install on pi4
pr0phet
Post by pr0phet »
Hi there. Ive got a trouble with install.
Raspbian buster pi4 as per wiki instruction.
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port: 80
HTTPS Port: 443
::: Destination folder=/home/pi/domoticz
::: Creating /home/pi/domoticz
--2020-05-18 08:11:33-- http://www.domoticz.com/download.php?ch ... ine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... 104.31.79.142, 104.31.78.142, 2606:4700:3036::681f:4e8e, ...
Connecting to www.domoticz.com (www.domoticz.com)|104.31.79.142|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://www.domoticz.com/download.php?c ... ine=armv7l [following]
--2020-05-18 08:11:33-- https://www.domoticz.com/download.php?c ... ine=armv7l
Connecting to www.domoticz.com (www.domoticz.com)|104.31.79.142|:443... connected.
GnuTLS: Error in the pull function.
Unable to establish SSL connection.
How to resolve that?
Sistem is up to date with all instructions.
sancla
Re: Unable to Install on pi4
Post by sancla »
Hi there,
Can you tell me what the command is that u used to start the installation?
Second, if it helps, you can also follow this guide to assist your with the installation:
https://sancla.com/domoticz/raspberry-p ... -domoticz/
Check these howto's: https://sancla.com
pr0phet wrote: Monday 18 May 2020 9:22 Ive got a trouble with install.
Can you try again? Maybe the system was too busy. I tested the download just now and it does work from my system.
domoticz.com seems to be under ddos attacks quite frequently and that could have caused your issue.
pr0phet
Post by pr0phet »
already tried to do with sancla
making install with curl -L https://install.domoticz.com | bash
i've tried for 2 day at least, with all instructions ive found on this forum
sancla
Post by sancla »
waaren wrote: Monday 18 May 2020 9:32
@Waren
Could this error be related to the Cloudflare security, redirecting the user as part of the Cloudflare DDOS mitigation?
Would it be an idea to use a second domain for installation (or a subdomain)?
@pr0phet
Can you connect to www.domoticz.com directly or are you getting the Cloudflare page verifyingyou are not a robot with captcha?
pr0phet
Post by pr0phet »
@sancla connectin' whithout any troubles
sancla wrote: Monday 18 May 2020 9:56 Could this error be related to the Cloudflare security, redirecting the user as part of the Cloudflare DDOS mitigation?
I have no knowledge of the cloudflare mechanisms (and no control over the setup either :) )
This area of domoticz is handled by / -via @gizmocuz
pr0phet
Post by pr0phet »
tried to change dns & proxy with same result :(
pr0phet
Post by pr0phet »
problem solved via anonymous proxy located in germany :?
Users browsing this forum: matekogon and 1 guest
