I want to start to use my (Androids) phone to control some devices of Domoticz by speech.
I know there are all kind of solution available to integrate Google Assistant in Domoticz, but I hope it can be done more easily.
What I thought of:
1. Paid version of Domoticz can make widgets on your phone that act like a stand-alone app. Just press a button on your phone and device is switched on / off, without opening Domoticz.
2. Google Assistant can open apps on your phone, say Open (start?) <application name> and the application starts.
So, would 1+2 be a simple solution?
Many thanks in advance.
John
Widget + Google Assistant
Re: Widget + Google Assistant
It seems that this won't work...I tried it and it didn't, but I was hoping that I did something wrong...
I will try to understand the more complex solutions then...
I've tried the same on my pixel device. Google Assistant seems to work perfectly fine. Have you tried checking your assistant settings?
Hi Richard,
I'm very curious: do you mean that this method works for you?
