Cheap ip camera which works fine in Domoticz
rick8245
Post by rick8245 »
For some test purposes I am looking for some cheap IP camera;s which will work als in Domoticz.
With cheap I mean .. max $20 :D
I now have a GUUDGO Y4A-ZA2 which works fine with an app on my smartphone but does not work in Domoticz. :cry:
Any ideas ??
thanks in advance
Rick
Geitje
Re: Cheap ip camera which works fine in Domoticz
Post by Geitje »
I think any cam with the possibility to get a snapshot using HTTP(S) is supported. You could check online/read the manual of any cam you plan to buy if it supports this feature.
Zwave, Zigate, RFlink etc.
rick8245
Post by rick8245 »
Hi Geitje
Thank you but can you give me some brands and types which are working in Domoticz.
If possible also some weblinks were to buy these brands and types
jvdz
Domoticz version: 4.107
Post by jvdz »
I saw this in their FAQ:Have you tried that?
Yes, but I'm not sure how well/fully supported it is. I have video, but no audio, the main video profile is only 1280x720 not 1920x1080, and the normal snapshot URL that my ONVIF client tries doesn't appear to work (there may be another one, but the ONVIF capabilities are undocumented). That said, I haven't really tried to get everything working.
The default ONVIF username is "admin" and the password is empty/blank.
rick8245
Post by rick8245 »
Hi jdvz,
I really tried everything and that's why I want to have some brands and types which you (forum members ) have running in Domoticz.
Than I am sure I will get this working too with the camera;s i will buy.
So which cheap IPCamera's do work smoothly in Domoticz ??
Thanks in advance
lost
Post by lost »
rick8245 wrote: Tuesday 12 May 2020 10:30 So which cheap IPCamera's do work smoothly in Domoticz ??
Don't have any example in the 20$ price range. Even buying from aliexpress, that's twice this figure to get something that is worth the try... and that's not 100% sure this' will be OK: Buy one, wait 2 weeks for the parcel, try... and make another order if this works & you need several ones.
Just one tip: Get away from cams that can only be configured from a smartphone app (i.e. not using http from a web browser thanks to an embedded configuraion web server hosted by the cam). You're almost sure to have issues if you don't stick to the manufacturer use-case (i.e. watching the cam from their smartphone app).
Geitje
Post by Geitje »
Checkout this site. It shows you a real lot of cams with their http snapshot links and which cam supports it (some cams have multiple entries, if jpeg is one of them, it should work).
https://www.ispyconnect.com/sources.aspx?
rick8245
Post by rick8245 »
Hi Geitje,
Thanks for the link but I tried all the GUUDGO camera links. But they do not work form the type I have which by the way is not on the list
Geitje
Post by Geitje »
I'm afraid it is not supported then. I googled the cam and tried to find other names/brands which use the same model. I cannot find it. It seems not to be very common.
rick8245
Post by rick8245 »
Hi Geitje,
Yesterday i have searched the internet for some hours and I finally found its username and passwd.
I can now logon to the devie (which is a unix busybox device) . At this moment I now have to find the url (rtsp or http) but it really is hard to find .
I keep on trying .
// Rick
Treve
Domoticz version: v4.11474
Post by Treve »
I use the Foscam C1, it streams perfectly to my Synology NAS surveillance.
Ik makes a perfect snapshot when someone push the (KAKU) doorbell.
The camera cost about €50,-
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Quest24
Domoticz version: 2025-2
Post by Quest24 »
You can also use Tasmota platform with ESP-32 Cam. Works over IP.
Settings in Domoticz Cam
IP your ip
Port 80
You can get a snapshot from Dzvents
domoticz.executeShellCommand('sudo wget -O ./webcam/foto.jpg "http://x.x.x.x.:80/snapshot.jpg" ')
the file is placed in domoticz/webcam/
HvdW
Domoticz version: 2023.2
Post by HvdW »
What about an ESP32?
Buy it somewhere on AliExpress or better at your local or regional components dealer. At Okophone it's a bargain!
Install it using these instructions.
Bugs bug me.
solarboy
Domoticz version: 2024.6
Post by solarboy »
I bought some of those ESP32 cams, I even upgraded the camera module on one. I found the picture quality to be unacceptably poor.
