Test button in notification widget
pierrotori
Domoticz version: 2024.4
Post by pierrotori »
is it possible to create a push test notification button in the notification parameter
When you push the button , you can test the condition and the message or perhaps only the message
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
azonneveld
Re: Test button in notification widget
Post by azonneveld »
Create a dummy device, switch.
Set the 'notifications' on that dummy device for on and off. Now toggle the dummy device manually.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
pierrotori
My suggestion is for all widget with a notification button because when a notification content a custom message, it's more easy to test
see my topic here : https://www.domoticz.com/forum/viewtopi ... 28&t=32644
