Time scheduled feature
- Domoticz version: v2022.2
Is anybody missing on timers do something every 10 /second/minutes/hours/week...and etc.?
DOCKERED v14824,NODE-RED,Tasmotized Sonoffs,Tasmoadmin,zigbee2mqtt,EWPE,REST980,WLED
- Domoticz version: V2022.1
Re: Time scheduled feature
Doing every 10 seconds something is not wise.
System will be very busy.
but every minuut, hour, day, week is no problem with DZvents
https://www.domoticz.com/wiki/DzVents:_ ... gger_rules
timer = {
'every minute', -- causes the script to be called every minute
'every other minute', -- minutes: xx:00, xx:02, xx:04, ..., xx:58
'every <xx> minutes', -- starting from xx:00 triggers every xx minutes
-- (0 > xx < 60)
'every hour', -- 00:00, 01:00, ..., 23:00 (24x per 24hrs)
'every other hour', -- 00:00, 02:00, ..., 22:00 (12x per 24hrs)
'every <xx> hours', -- starting from 00:00, triggers every xx
-- hours (0 > xx < 24)
'at 13:45', -- specific time
'at *:45', -- every 45th minute in the hour
'at 15:*', -- every minute between 15:00 and 16:00
'at 12:45-21:15', -- between 12:45 and 21:15. You cannot use '*'!
'at 19:30-08:20', -- between 19:30 and 8:20 then next day
'at 13:45 on mon,tue', -- at 13:45 only on Mondays and Tuesdays (english)
'on mon,tue', -- on Mondays and Tuesdays
'every hour on sat', -- you guessed it correctly
'at sunset', -- uses sunset/sunrise info from Domoticz
'at sunrise',
'at civiltwilightstart', -- uses civil twilight start/end info from Domoticz
'at civiltwilightend',
'at sunset on sat,sun',
'xx minutes before civiltwilightstart', --
'xx minutes after civiltwilightstart', -- Please note that these relative times
'xx minutes before civiltwilightend', -- cannot cross dates
'xx minutes after civiltwilightend', --
'xx minutes before sunset',
'xx minutes after sunset',
'xx minutes before sunrise',
'xx minutes after sunrise' -- guess ;-)
'between aa and bb' -- aa/bb can be a time stamp like 15:44
-- aa/bb can be sunrise/sunset
-- aa/bb can be 'xx minutes before/after sunrise/sunset'
'at civildaytime', -- between civil twilight start and civil twilight end
'at civilnighttime', -- between civil twilight end and civil twilight start
'at nighttime', -- between sunset and sunrise
'at daytime', -- between sunrise and sunset
'at daytime on mon,tue', -- between sunrise and sunset only on Mondays and Tuesdays
'in week 12,44' -- in week 12 or 44
'in week 20-25,33-47' -- between week 20 and 25 or week 33 and 47
'in week -12, 33-' -- week <= 12 or week >= 33
'every odd week',
'every even week', -- odd or even numbered weeks
'on 23/11', -- on 23rd of november (dd/mm)
'on 23/11-25/12', -- between 23/11 and 25/12
'on 2/3-18/3',11/8,10/10-14/10',
'on */2,15/*', -- every day in February or
-- every 15th day of the month
'on -3/4,4/7-', -- before 3/4 or after 4/7
-- or if you want to go really wild and combine them:
'at nighttime at 21:32-05:44 every 5 minutes on sat, sun',
'every 10 minutes between 20 minutes before sunset and 30 minutes after sunrise on mon,fri,tue on 20/5-18/8'
-- or just do it yourself:
function(domoticz)
-- you can use domoticz.time to get the current time
-- note that this function is called every minute!
-- custom code that either returns true or false
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
Thanks for reply. I know about it. But if i want timer which do something for ex. every 6 hours, so when you enter scripts its automatically reseted and its starting from zero (for example you need to repair or add script which has nothing to do with this script).
PS: not everybody is well oriented in scripts so can be difficult for them to apply something what is not copy/paste style
- waaren
This is not how dzVents works.
If you use 'every 6 hours' , the script will be triggered at 06:00:00 , 12.00.00, 18:00:00 and 00:00:00
And 'every 360 minutes' ??
- waaren
as per the wiki: the number of minutes in the rule must be > 0 and < 60
every 360 minutes will generate below error'every <xx> minutes', -- starting from xx:00 triggers every xx minutes
-- (0 > xx < 60)
Error: dzVents: Error: (3.0.5) every 360 minutes is not a valid timer definition. Can only run every 1, 2, 3, 4, 5, 6, 10, 12, 15, 20 and 30 minutes.
Yes, you'r right!
As i said, iam not good at scripts and the script you postetd is surelly not copy/paste. For example if i want every 4 hours from device change state or whatever its not written there and i need to know dz events.
- Egregius
- Domoticz version: v2024.7
Or you can try pass2php. Pretty easy there to do something x secondes after last switch.
Just something like past('switchname')>3600 will do.
