button pressed vs script activating
fireport
Post by fireport »
I have a blocky script than activate/deactivate a venting fan based on humidity value. The script works ok but I would like to override this behavior pushing the sonoff basic button that controls the fan. So, if I will press the button the fan should stay on until I will press the button again despite humidity level.
Sonoff is connected to a Mosquitto server
Any idea ?
Many thanks in advance
wouterlet
Re: button pressed vs script activating
Post by wouterlet »
You could use a user variable:
If you push the burron the fan goed on and sets the user variable to 1. Of you push it to go off then make the variable 0.
In your existing scripts you add user variable = 0 to the if and elseif
fireport
Post by fireport »
How can I set a user variable when i push the button on sonoff?
fireport
button pressed vs script activated [SOLVED]
Post by fireport »
I solved with this script
and this rule in tasmota
rule1 on Button1#state=2 do backlog publish domoticz/in {"command":"setuservariable","idx":4,"value":"2"}; POWER TOGGLE ENDON
where idx 4 is ID of variable stato_cappa
