Irrigation garden with buienradar Topic is solved
remko2000
I can give my gardenplants water with a domoticz on/of switch (with off timer). I want on daily basis water my plants but not when it rains that day. I have also a buienradarswitch ' it rains' in domoticz.
What is the easiest way to script this which I involed the rainswitch? Is it possible whit a blocky? I have no knownledge of lua/dzventz.
niki_lauda
Re: Irrigation garden with buienradar
Maybe read this topic. https://www.domoticz.com/forum/viewtopi ... in#p205499
remko2000
I saw this tread. The problem I encountered is that most of the example scripts are based on Weatherundergroundinfo. WU doens't provided free API's anymore so I use primarily Buienradar. I tried a couple of times to adjust a script to buienradarsensors but that is by no means an easy task for me.
wouterlet
Please post you're blocky here. That's easier to see what's going wrong
remko2000
I made this blocky:
I want that only in the evening/night (between 20.00 and 8.00 hour) my irrigation (waterpomp) goes on when my 'lavendel voch' is above 30 (cb).
It's switch off itself.
Is this the correct way or do I have to use variables? And how do I use this?
wouterlet
I think it could be able to work, but time can't be after 20:00 and before 8:00. Blocky only thinks in one day. Change the and between the time in or and I think it will work.
remko2000
Thx. I adjust it but my blocky doesn't work. After trying some things it looks like the problem is the variable 'lavendel vocht'. If I try another randow variable (by example the lux value outside) it does work.What is the problem with this variable and can I fix this or is there another workaround?
- waaren
What is the devicetype / subtype for the device lavendel vocht as shown on the devices tab ?remko2000 wrote: Tuesday 05 May 2020 10:16 After trying some things it looks like the problem is the variable 'lavendel vocht'.
And please also show the Blockly as it is now after you made the changes in time logic in you answer.
iganin
- Domoticz version: 2020.2
The best time is watering garden is in mornings )
remko2000
this is my blocky now (I switched to fixed time):
'Lavendel vocht' is type 'General, Soil Moisture'
- waaren
Because the Soil Moisture device stores its moisture value in another place then most other devices (it uses nValue while most other utility devicetypes use sValue), Blockly is not able to evaluate the value.
You could try below dzVents alternative.
timer =
'at 09:00',
'at 21:00',
logging =
level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when OK
marker = 'Beregening',
execute = function(dz)
local soilDevice = dz.devices('Lavendel vocht')
local moisture = soilDevice.moisture
local pump = dz.devices('Waterpomp')
dz.log(soilDevice.name .. ' measures a moisture of ' .. moisture .. ' cb ',dz.LOG_DEBUG)
if moisture < 30 then -- Should this be more ( > ) or less ( < )then 30 ?
pump.switchOn()
pump.switchOff().afterSec(3600)
dz.notify('Beregening', 'De planten worden automatisch beregend',dz.PRIORITY_NORMAL)
}Debian buster, bullseye on RPI-4, Intel NUC.
remko2000
I try this dzvents script and it works! Great!
Only strange thing is that only the time ' 21:00' works and ' 09.00' not. Maybe it is: 9:00 and not 09:00?
- waaren
09:00 and 9:00 should both work. But I see in your post that you use 09.00 ?remko2000 wrote: Friday 08 May 2020 9:10 Only strange thing is that only the time ' 21:00' works and ' 09.00' not. Maybe it is: 9:00 and not 09:00?
the hour minute divider must be a :
What version do you use ?
remko2000
I use 2020.2 (latest stable). In use for both times ':' .
If I change to 10:30 It looks likes the script is now running
I checked my log:
It measures 25CB so it's less than 30 so irrigation is not needed.
I checked my log:
2020-05-08 10:30:00.529 Status: dzVents: Info: Beregening: ------ Start internal script: Irrigatiescript2:, trigger: "at 10:30"
2020-05-08 10:30:00.530 Status: dzVents: Debug: Beregening: Processing device-adapter for Lavendel vocht: Soil Moisture device
2020-05-08 10:30:00.531 Status: dzVents: Debug: Beregening: Processing device-adapter for Waterpomp: Switch device adapter
2020-05-08 10:30:00.532 Status: dzVents: Debug: Beregening: Lavendel vocht measures a moisture of 25 cb
2020-05-08 10:30:00.532 Status: dzVents: Info: Beregening: ------ Finished Irrigatiescript2- waaren
Then please try again tomorrow with the original 'at 09:00'. I just retested with this and it does work as designed.remko2000 wrote: Friday 08 May 2020 10:45 If I change to 10:30 It looks likes the script is now running
zavjah
[quote=remko2000 post_id=246340 time=1588676346 user_id=17935]
[/quote]
Hello remko2000,
I want to set up an Automat irrigation, too, supported by a soil moisture sensor. Can you tell me which device do you use to get the soil moisture into Domoticz?
Thx,
Zavjah
[/quote]
Hello remko2000,
Thx,
Zavjah
dheuts
I use the Mi Flora sensors of Xiaomizavjah wrote: Monday 25 May 2020 17:26Hello remko2000,remko2000 wrote: Tuesday 05 May 2020 12:59 this is my blocky now (I switched to fixed time):
Thx,
Zavjah
Raspberry Pi 4 With Domoticz - RFXCom - Tuya Wifi LED lights - Chuango Alarm - Zwave+ - Zigbee2MQTT - Anna Thermostat - Broadlink IR, P1 - Eufy Robo Vacuum - Worx Robo Mower
dheuts
Hi Waaren,
Good morning.
I was having the same problem with my Xiaomi Mi Flora Sensors.
Getting this errors:
2020-08-21 10:03:00.354 Error: EventSystem: Lua script error (Blockly), Name: Tijd Planten meldingen_5 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare nil with number
2020-08-21 10:03:00.354 Error: EventSystem: Lua script error (Blockly), Name: Tijd Planten meldingen_6 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare nil with number
I have got 4 sensors, and want to get notifications like you can see in my Blockly.
Can you please help me how to make a script in dzVents so this works?
I already edited your script so it works for one of the sensors for the water. How to make this script working for all 4 plants and also the plant food sensors?
timer =
'at 09:39',
logging =
marker = 'Plant Meldingen',
local soilDevice = dz.devices('Zolder Bananenboom Vochtigheid')
if moisture < 20 then -- Should this be more ( > ) or less ( < )then 30 ?
dz.notify('Bananenboom water', 'De Bananenboom moet water hebben',dz.PRIORITY_NORMAL)
}- Attachments
- bananenboom.png (31.43 KiB) Viewed 4397 times
- waaren
Happy to help but need some additional information.dheuts wrote: Monday 24 August 2020 9:34 Can you please help me how to make a script in dzVents so this works?
Names, types and subtypes of all involved sensors
Per plant the water- and foodlimits to decide when notification is required.
- kiddigital
What/which device do you use and how is it connected? Looking for something myselfremko2000 wrote:...
The Gardena one is quite expensive and needs cloud connection which I am not really in favor off
