Zigate and Aqara 2 button remote switch
ronaldbro
- Domoticz version: 2020.2
Hi Pipiche,
I successfully paired two Aqara 2 button remote switches, but I don't get any events when I press one of the buttons. I had them on zigate before and then they worked without any problems. But now with the latest beta they don't do anything.
Can you please help?
Regards Ronald
Regards Ronald
ronaldbro
Re: Zigate and Aqara 2 button remote switch
I do notice an error during binding and a create group message which I don't understand.
Maybe this helps.
2020-05-02 21:57:42.810 Status: (Zigate2) Device Announcement Addr: 9bd1, IEEE: 00158d00031360ed Join Flag: 0x99 - Unknown value received. RSSI: 0
2020-05-02 21:57:43.827 Error: (Zigate2) ReadCluster - 0000 - 9bd1/01 Attribut ff01 received while device not inDB
2020-05-02 21:57:47.547 Status: (Zigate2) [0] NEW OBJECT: 9bd1 Model Name: lumi.remote.b286acn01
2020-05-02 21:57:52.510 Status: (Zigate2) [1] NEW OBJECT: 9bd1 Model Name: lumi.remote.b286acn01
2020-05-02 21:57:57.554 Status: (Zigate2) [2] NEW OBJECT: 9bd1 Model Name: lumi.remote.b286acn01
2020-05-02 21:58:02.540 Status: (Zigate2) [3] NEW OBJECT: 9bd1 Model Name: lumi.remote.b286acn01
2020-05-02 21:58:07.575 (Zigate2) Creation Group
2020-05-02 21:58:07.556 Status: (Zigate2) [4] NEW OBJECT: 9bd1 Model Name: lumi.remote.b286acn01
Maybe this helps.
Not an issue
ronaldbro
Ok, but not receiving the events anymore is
The switches are useless now
So if I summarize, you have been able to pair those 2 Aqara buttons, corresponding widgets have been created, but what ever you do on the button you don't see on Domoticz nor on the logs ?
Did you check the battery ?
ronaldbro
Yep, that is correct.
I replaced the battery of one of them and rebind, but it didn't make a difference. I used them before on zigate and yesterday they also worked fine on the Xiaomi hub.
ronaldbro
When I delete the widget and press a button I do get something is the log:
See also my raw device list attached. I tested with "Test switch".
Thanks for your help.
- Spoiler: show
- export.json (5).txt
- (97.86 KiB) Downloaded 44 times
Indeed the Device you name 'Test switch' is communicating.
(1) It looks like it changes its Network Address, and the plugin reconnect it.
Could you get the latest beta branch
and redo the test with enabling debugWidget debugCluster
And share the logs when actioning the device
ronaldbro
Sure, here is the result. Short adress is 61f6
- Spoiler: show
seems that I own you a beer .
Try with the new version on beta
ronaldbro
haha, its beta so it's ok
I updated to latest beta, restarted domoticz, delteted the widget and rebind. And the result is the same, no evets.
- Spoiler: show
Will look tonight
ronaldbro
Ok, thanks
if you can try once more ?
just update beta branch, no need to remove the device and redo the pairing
ronaldbro
Yes, it works again
I did found a typo, "Left double clink" should be "Left double click".
Thanks Pipiche
Thanks Pipiche
Geitje
I was too early. I have likewise problem with my single button Aqara battery wall switch. It seems connected, but no reaction to switching, nothing in logs.
I had an hard time to re-include my switch after I removed it yesterday. Did git pull (now on 4.8.22) an re-including only was successfull after 8 times or so. But I read that is more often a problem with Aqara. Now I succesfully included it, it is still not reporting switches.
It is this switch:
It is this switch:
- Spoiler: show
Zwave, Zigate, RFlink etc.
ronaldbro
Yep, that’s it. I never have problems binding Aqara devices. Only a few THB devices last week with low battery.
Maybe your battery is low also
Geitje
OK, I changed the battery. Unpaired the switch, and re-paired it. Paring went OK first try. However still no reaction to pushing the switch.
EDIT: saw there was again an update of the plugin. After new git pull it works... Thanks Pipiche!
- LOG.txt
- (9.66 KiB) Downloaded 44 times
