Fixed* V2020.2 Remote shared device (percentage) not working Topic is solved
BarryT
Domoticz version: 2024.3
Post by BarryT »
i have a lot of remote, shared devices that works correctly only a "percentage" device does not working correct.
It does see the device, but it stays at 0% while on the master the device is updated every second to a value.
It is a important device because it will switch on / off a level to a tank.
It is also possible with a script, php/lua/json, but i did a try for some hours but give it up, it doesnt work.
Hope to find the answer!
**EDIT:
Nevermind, i had to update the remote to the latest version.
It was still running 2020.1 while the master had 2020.2.
Problem solved, thanks!
