Pass2PHP
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
Look at the few lines I posted of the pass2php file. You'll have to add your device to that array.
At the moment it'll only take the temperature as I don't care about humidity etc.
Trigun
Domoticz version: 4.10717
Re: Pass2PHP
Post by Trigun »
ok, the log is stil saying the following
03-20 16:05:01.759 STATUS ==> Outdoor temperature = 4.3
2020-03-20 16:05:01.759 STATUS ==> Indoor temperature = 20.7 C, 47 %, 1014.6 hPa
2020-03-20 16:05:01.759  (SWITCH)                => Duco-afzuiging => Off ()
I've changed the pass2phpfile file to:
} elseif (in_array($device, array('Indoor-Temp&Hum'))) {
    $status=explode(';', $status);
    $status=$status[0];
I don't think its working yet
Egregius
Re: Pass2PHP
Post by Egregius »
I see now. Yours has a comma as separator, mine has semicolon. Change the ; to , in the explode.
Trigun
Re: Pass2PHP
Post by Trigun »
I'm Sorry I must have turned blind as I cannot see what you mean.
I've checked it all but cannot find any differences :?
Egregius
Re: Pass2PHP
Post by Egregius »
Your logfile shows:
Which means that the fields in the status of your indoor temperature are separated with a comma.
On line 29 of https://github.com/Egregius/PHP-Floorpl ... ss2php.php
the status of the devices in the array on line 28 are exploded by a semicolon.
That's why your status doesn't get exploded into a array.
Copy lines 28-30 to a new elseif block:
} elseif (in_array($device, array('badkamer_temp'))) {
    $status=$status[0];
to
    $status=$status[0];
    $status=explode(',', $status);
    $status=$status[0];
    $humidity=$status[1];
    $baro=$status[2];
It's up to you to decide if you need to add the $humidity and $baro lines and how to handle them. Maybe with a storemode.
Or don't explode them there and only explode them when you need them. That would be something like this:
$data=explode(',', $d['Indoor-Temp&Hum']['s']);
$indoortemp=$data[0];
$indoorhumidity=$data[1];
$indoorbaro=$data[2];
if ($d['Outdoor-Temp&Hum']['s']>=$indoortemp){
	sw('Duco-afzuiging', 'Off');
Trigun
Re: Pass2PHP
Post by Trigun »
hi all,
will pass2php work with mariadb?
since the upgrade to version 2020.1 msql is no longe possible to install.
thnx!
Egregius
Re: Pass2PHP
Post by Egregius »
Of course. Mariadb is the default mysql server in buster.
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
Works like a charm. :lol:
Needed to update the php settings ofcourse to different 7.3 "sock" as that will be upgraded as well.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Trigun
Pass2PHP
Post by Trigun »
sincze wrote:Works like a charm. :lol:
How did you install mcrypt? As it cannot be installed the usual way
Also how did you install the right mariadb?
Egregius
Re: Pass2PHP
Post by Egregius »
I don't think I have mcrypt installed, don't even know what it's used for :lol:
I have these mariadb packages installed:
mariadb-client-10.3/stable,stable,now 1:10.3.22-0+deb10u1 amd64 [installed,automatic]
mariadb-client-core-10.3/stable,stable,now 1:10.3.22-0+deb10u1 amd64 [installed,automatic]
mariadb-common/stable,stable,now 1:10.3.22-0+deb10u1 all [installed,automatic]
mariadb-server-10.3/stable,stable,now 1:10.3.22-0+deb10u1 amd64 [installed,automatic]
mariadb-server-core-10.3/stable,stable,now 1:10.3.22-0+deb10u1 amd64 [installed,automatic]
Don't know why I have mariadb-server-10.3 instead of mariadb-server
Trigun
Re: Pass2PHP
Post by Trigun »
I always thought that php relied on Mcrypt but I guess its not necessary anymore?
Egregius
Re: Pass2PHP
Post by Egregius »
If you install php the dependencies will also be installed. No need to worry about that.
Trigun
Re: Pass2PHP
Post by Trigun »
Great! I got it all working again! :)
is it me or does is it working faster with OZW 1.6?
anyway, again very happy with pass2php!
Egregius
Re: Pass2PHP
Post by Egregius »
Don't know if OZW 1.6 is the cause, been running it for months now.
All I know, it works lighting fast and rock solid :lol:
Egregius
Re: Pass2PHP
Post by Egregius »
Finally got my Daikin airconditioners installed :D
Of course, these are now also useable directly in pass2php :mrgreen:
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote:Finally got my Daikin airconditioners installed :D
Cool!!$ which ones did you purchase. I am looking for an airco as wellImage would be cool to add it to pass2 php.
Also perhaps anyone has some experience with adding a Samsung tv?
sincze
Re: Pass2PHP
Post by sincze »
I'm Old school ..
LG Airo here since 2012 non-smart here ;-)
Did install a shelly to measure the power usage :lol:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
I installed the 3MXM52N multi R32 in combination with 1x Perfera FTX-M35 and 2x Perfera FTX-M20.
ropske
Domoticz version: V3_8394
Re: Pass2PHP
Post by ropske »
Hi guys, well i think of returning back to domoticz lol and this php script.
I changed to Homey to try, but it does not give what i want.
Its very good i think for a user that doesn't know anything about programming.
But if want to switch on a light and switch off after x seconds, lol you need to do a lot.
Even for my heating in my house, djeezes , its to cry what i need to do lol
Now, i had domoticz running before on a raspberry pi. But then some strange things happened (i think Egrerius remembers? i have spoken to you sometimes and you were also out of options :D)
Now, what system do you advice to my to run domoticz on with aeon zwave plus stick?
Thank you!
Egregius
Re: Pass2PHP
Post by Egregius »
Damn, another few hundred euro in the trash, hope you can resell it.
Any raspberry should run Domoticz perfectly, keeping in mind SD card troubles.
For a truly worry free set up:
Use a Intel Nuc (or something similar). I have the Intel Baby Canyon NUC7i3BNH. I recently added 16GB ram so I'm at 24GB ram and I replaced the SATA SSD to a Samsung 970 EVO PLUS M2.SSD.
I installed ProxMox on it as a hypervisor. That permits to run multiple virtual machines on 1 computer. That's the main reason for the extra memory. I also added a extra network card.
In Proxmox I installed several virtual machines:
- pfSense firewall and add blocker. All my internet traffic passes this router.
- Domoticz with Aeotec Z-Wave and RFXCOM.
- A Windows 10 workstation because I use a Mac mainly but sometimes need Windows.
- Some linux distro's that only run to test some stuff.
One of the greatest advantages of the Proxmox setup is that you can easily take whole system snapshot to a NAS or external HD. If the nuc dies I can quickly run Proxmox from USB on a laptop and restore the snapshots until a new Nuc is delivered. In my home everything is handled from Domoticz. Every light, every roller, music, tv, heating, airco, everything. There are even rooms and outlets that can't be switched on without domoticz. So I cannot afford any downtime.
Agreed, it's quite more expensive than a Raspberry but it gives a lot in return. If you have on old laptop laying around that could also be a good option. You mainly want something that's stable and doesn't consume to much power.
