dzvents Pushover notification without domoticz.notify  [Solved]
Ragdag
Post by Ragdag »
Both my wife and I have a Pushover account and for I created a Pushover Application for Domoticz, also created a Group with the User ID of my wife and me.
When using
domoticz.notify("Title", "Message.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , domoticz.NSS_PUSHOVER)
we both get a notification.
Now there are certain notifications that not both of us need to get so it would be nice te be able to create a different App in PushOver that only my wife will get and one just for me.
The problem then becomes that I can't configure that in Domoticz.
Is there an alternative way to send PushOver notification from dzvents
Re: dzvents Pushover notification without domoticz.notify
Ragdag wrote: Sunday 19 April 2020 20:01 Is there an alternative way to send PushOver notification from dzvents
If you have multiple application API tokens and user/group key s you can do it with
scriptVar = 'myPushover'
return
    on =
        devices =
            'pushOverTrigger',
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar
    execute = function(dz, item)
        if item.isHTTPResponse then
            dz.log(item.data,dz.LOG_DEBUG)
            local users =
                ['Jan'] = { ['token'] = 'a5mxxxxxxxxxxx', ['key'] = 'u1wxxxxxxxxxxxxxxxxxxx' },
                ['Piet'] = { ['token'] = 'a5myyyyyyyyyyyyyyy', ['key'] = 'u1wyyyyyyyyyyyyyyyyyy'},
                ['Joris'] = { ['token'] = 'a5mzzzzzzzzzzzzzz', ['key'] = 'u1w5zzzzzzzzzzzzzzzzzz'},
           local function pushover(user, message, title, priority, sound)
                dz.openURL({
                    url = 'https://api.pushover.net/1/messages.json',
                    method = 'POST',
                    callback = scriptVar,
                    postData =
                        token = user.token,
                        user =  user.key,
                        message = message,
                        title = title or 'Pushover from dzVents',
                        priority = priority or 0,
                        sound = sound or 'echo',
            pushover(users.Jan, 'pushover unique user')
            pushover(users.Joris, 'en Corneel','Joris', 1, 'echo' )
            pushover(users.Piet, 'message to piet','Only for Piet', 1, 'siren' )
Ragdag
Post by Ragdag »
waaren wrote: Sunday 19 April 2020 23:53
return
    on =
        devices =
            'pushOverTrigger',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar
            local users =
                dz.openURL({
                    method = 'POST',
                    postData =
                        token = user.token,
                        user =  user.key,
                        message = message,
As always fast and perfect 😀
Will give this a try, thank you.
Ragdag
Post by Ragdag »
return
    on =
        devices =
            'pushOverTrigger',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar
            local users =
                dz.openURL({
                    method = 'POST',
                    postData =
                        token = user.token,
                        user =  user.key,
                        message = message,
Would this be something that I put in each dzvents script or would this be a standalone script which I can call from the scripts I need it in.
For instance I have a simple Washing machine done script, how would I integrate it into that?
return
    on =
        timer = {'every 1 minutes'}
    logging =
        --level = domoticz.LOG_DEBUG,
        marker = "Wasmachine"
    data =
       WasmachineTimeout = { initial = 1 },
       WasmachineInUse = { initial = 0 },
    execute = function(domoticz)
        local WasmachineUsage = domoticz.devices(275)
        local WasmachineStandbyUsage = 5.5
        if (WasmachineUsage.actualWatt >= WasmachineStandbyUsage) then
            if (domoticz.data.WasmachineInUse == 0) then
                domoticz.data.WasmachineInUse = 1
                domoticz.notify("Wasmachine aan", "De was wordt gestart.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "Nicky" , domoticz.NSS_PUSHOVER)
            elseif (domoticz.data.WasmachineTimeout == 0) then
                domoticz.data.WasmachineTimeout = 1
        if (WasmachineUsage.actualWatt <= WasmachineStandbyUsage) and (domoticz.data.WasmachineInUse == 1) then
            if (domoticz.data.WasmachineTimeout > 0) then
                domoticz.data.WasmachineTimeout = domoticz.data.WasmachineTimeout - 1
                domoticz.data.WasmachineInUse = 0
                domoticz.notify("Wasmachine klaar", "De was is klaar.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , domoticz.NSS_PUSHOVER)
                domoticz.notify("Wasmachine klaar", "De was is klaar.", domoticz.PRIORITY_NORMAL, domoticz.SOUND_NONE, "" , domoticz.NSS_KODI)
Re: dzvents Pushover notification without domoticz.notify  [Solved]
Ragdag wrote: Tuesday 21 April 2020 14:36 Would this be something that I put in each dzvents script or would this be a standalone script which I can call from the scripts I need it in.
If you only use it in one or two script then I would integrate it into these scripts like attached.
But if you expect to use it in many scripts then I suggest to make it a dzVents Shared helper function
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar,
    logging =
    data =
    	dz = domoticz
            return
        local function pushover(user, title, message, priority, sound)
            dz.openURL({
                method = 'POST',
                postData =
                    token = user.token,
                    user =  user.key,
                    message = message,
        local users =
                -- domoticz.notify("Wasmachine aan", "De was wordt gestart.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "Nicky" , domoticz.NSS_PUSHOVER)
                pushover(users.Jan,  "Wasmachine aan", "De was wordt gestart.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT )
                -- domoticz.notify("Wasmachine klaar", "De was is klaar.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , domoticz.NSS_PUSHOVER)
                pushover(users.Piet,  "Wasmachine klaar", "De was is klaar.", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT )
Ragdag
Post by Ragdag »
waaren wrote: Tuesday 21 April 2020 15:19
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar,
    logging =
    data =
            return
            dz.openURL({
                method = 'POST',
                postData =
                    token = user.token,
                    user =  user.key,
                    message = message,
        local users =
This works great, just needed to change the dz.openURL and dz.log to domoticz.openURL and domoticz.log otherwise I got an:
2020-04-21 17:13:01.368 Error: dzVents: Error: (3.0.2) Wasmachine: An error occurred when calling event handler Was_Notification
2020-04-21 17:13:01.368 Error: dzVents: Error: (3.0.2) Wasmachine: ...z/scripts/dzVents/generated_scripts/Was_Notification.lua:32: attempt to index a nil value (global 'dz')
Ragdag
Post by Ragdag »
return
    on =
        devices =
            'pushOverTrigger',
        httpResponses =
            scriptVar,
    logging =
        marker = scriptVar
            local users =
                dz.openURL({
                    method = 'POST',
                    postData =
                        token = user.token,
                        user =  user.key,
                        message = message,
It works but I'm trying to figure out how it works and I understand the most of it but there is one thing that is baffling to me, this piece
                        token = user.token,
                        user =  user.key,
I would expect it to be users to refer back to the array you created.
                        token = users.token,
                        user =  users.key,
Ragdag wrote: Wednesday 22 April 2020 10:20 I would expect it to be users to refer back to the array you created.
                        user =  users.key,
In the call to the function I do not pass the complete table users but only the sub-table users.Jan via the first parm (user)
So within the function this sub-table is known as user
Ragdag
Post by Ragdag »
waaren wrote: Wednesday 22 April 2020 10:59
                        user =  users.key,
Thank you, I think I understand but I also feel my brain bending while trying to figure it out :lol: .
I've started to experiment with the global_data method you referred to but after spending a few hours on it, building small test portions of code to see if it works I think this might be beyond my grasp :oops:
