Is there anything I can do to speed up the initial install / compile of domoticz?
On my raspberry pi3b+ (running rasbian) it is taking hours to complete.
I might have something not done right... ??????
any ideas?
Installation of domoticz takes forever Topic is solved
- Domoticz version: 4.11539
Hardware: Raspberry Pi 3, OTGW, 433MHz Superheterodyne 3310 RF Link
Software: Ubuntu 16.04, Domoticz v3.5468, WiringPi, rc-switch
- Domoticz version: Stable
Re: Installation of domoticz takes forever
Must be something wrong indeed.
SD card broken ?
Any hint in the text on the screen?
SD card broken ?
no hints, compile just takes forever (as in more than 60 minutes..
eventually it will finish with no errors..
I have a 32GB Samsung EVO microsd.
- waaren
60 minutes is not bad for compiling the first time on a RPI 3B.
Did you use a swap file as per the recommendations on the wiki ?
On a raspberry PI compilation could take a long time. Suggested is to use a swap file (see above) if you have less then 4GB of memory
Initial build:
RPI-4: 28m.40s
aa cr**p
yes I did not do that step!
that was probably the problem!
Will not test it thou
the system is up and running now
- Domoticz version: 2022.1
I compiled myself Domoticz on an old Sony Vaio netbook (Atom CPU...) as the easy install script gives a 404 error for a 32bit CPU. It took almost all night to compile, but it's up and running now
. Only 2GB ram and without swapfile
Users browsing this forum: Ahrefs [Bot] and 1 guest
