Zigate and Xiaomi light sensor
ronaldbro
Post by ronaldbro »
Hi Pipiche,
I bought a few Xiaomi light sensors (http://s.aliexpress.com/MJNfMFbI) and successfully added it to domoticz using the latest stable version of the plugin and firmware 3.1a. But I don't get any value updates, lux stays on 0.
Do you know if there are still some issues with this sensor?
The sensor is pretty new and I noticed it is one of the newest sensors added to the zigate plugin. Maybe I should switch to beta for this sensor.
Any advice would be very welcome.
Thanks Ronald
pipiche
Re: Zigate and Xiaomi light sensor
Post by pipiche »
ronaldbro wrote: Friday 17 April 2020 19:24 Hi Pipiche,
Thanks Ronald
It is a bit hard to answer.
Could you provide and export of the "Plugin Devices raw (json)" that you can find on the Web Admin Page ?
We have recently added a Lumi Lux sensor on the beta branche, but I need to check if that is the same
ronaldbro
Post by ronaldbro »
Sure, see attached.
Thanks for your help
export.json (3).txt
(109.68 KiB) Downloaded 86 times
pipiche
Post by pipiche »
Please do update to the laresr version of the plugin (just posted now ;-)
Then
1- restart the plugin
2- Remove the Widget created for this device
3- Redo the pairing
The fix was available on beta. I just push it towards stable
ronaldbro
Post by ronaldbro »
Works perfectly :)
Thanks Pipiche
ronaldbro
Post by ronaldbro »
Hi Pipiche,
The sensor works perfect and very fast, really like them.
But I noticed that I don't receive the battery state, is this still work in progress? Hopefully I don't need to know the battery state for some time, but they send a lot of updates so I don't expect the battery to last a year. (Hopefully I'm wrong and that would make them absolutely perfect)
Thanks for your good work.
ronaldbro
Post by ronaldbro »
Hi Pipiche,
Now that I've switched to beta I can confirm that the beta als doesn't report battery status.
Hope it is on your todo list ;)
Regards Ronald
pipiche
Post by pipiche »
It is not on my todo as it works fine on my end. Could you clarify what version of Domoticz you are using ?
ronaldbro
Post by ronaldbro »
I use 2020.2 stable. I did create the widget using the stable plugin. Should I try to remove the widget and rebind?
ronaldbro
Post by ronaldbro »
Also the plugin doesn't show the battery percentage and the sensors are in the network for 2 weeks now.
pipiche
Post by pipiche »
could you please provide the export of Plugin Raw Device (JSON) ?
ronaldbro
Post by ronaldbro »
Sure, see attached
export.json (6).txt
(145.04 KiB) Downloaded 74 times
pipiche
Post by pipiche »
SO iI guess we are talking about the new Lux sensor. Please do update the beta branch. This should work now
ronaldbro
Post by ronaldbro »
Yep. Thanks.
I'll let you know the result
ronaldbro
Post by ronaldbro »
Great, it works. First one has a reported battery percentage, I'm sure the other two will follow.
Thanks again.
