Can not change icones for switch Lightning 6
xavierlp
Post by xavierlp »
Hello all
I need your help on this case : (may be a bug)
On my switch with type lightning 1, I can change the icone.
bureau Light 1.png (10.84 KiB) Viewed 830 times
bureau Light 2.png (14.07 KiB) Viewed 830 times
On switches with lignthin 6 : no options....
entree Light 1.png (12 KiB) Viewed 830 times
I couldn't find anytging about that. Is it a bug ?
I'm using 2020.1 on RPI4
Thanks a lot for any ideas.
xavierlp
Re: Can not change icones for switch Lightning 6
Post by xavierlp »
entree Light 2 (2).png (11.79 KiB) Viewed 829 times
xavierlp wrote: Thursday 16 April 2020 10:54 I need your help on this case : (may be a bug)
Can you please try and test by changing line 8 of <domoticz dir>/www/app/devices/deviceFactory.js from
                return ['Light/Switch', 'Lighting 1', 'Lighting 2', 'Lighting 5','Color Switch'].includes(device.Type) &&
to
               return ['Light/Switch', 'Lighting 1', 'Lighting 2', 'Lighting 5','Lighting 6','Color Switch'].includes(device.Type) &&
and clear browser cache and app cache (different things)
Maybe also a domoticz restart is needed.
If successful I will create a PR for this
xavierlp
Post by xavierlp »
Yesssss
It works : Thanks a lot :D
xavierlp
Post by xavierlp »
Dear Waaren,
If you can also add "Home Confort", It could be great.
I could test it, and it works also
thanks again
xavierlp wrote: Sunday 19 April 2020 22:55 If you can also add "Home Confort", It could be great.
Can you please explain what this is and attach a screenshot of the current icon ? I have no idea what this is.
xavierlp
Post by xavierlp »
xavierlp
Post by xavierlp »
Hello it is a device for a lamp
By défaut only the lamp icone is available
I could update the line 8 to have this :
xavierlp
Post by xavierlp »
xavierlp wrote: Monday 20 April 2020 22:22 A picture says more .....
OK clear. I created Pull Request #4089 . If @gizmocuz is OK it will be merged in one of the next Beta's
xavierlp
Post by xavierlp »
Thanks again
