Domoticz App
- FearNaBoinne
- Domoticz version: 2021.1
Re: Domoticz App
The Github says it's not available on Apple's AppStore yet because it is still beta... But the site links to the App on Appstore...
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
- DewGew
- Domoticz version: V4.10618
Re: Domoticz App
I have same problem. I had to remove the app then install it again. But when I activated security setup it crashed again. Now I reinstalled it without activate security it works.vgr2 wrote: Wednesday 08 April 2020 18:47 Latest App Version is not working on my iOS 13.4.1.
App is starting and shutting down directly….
- galadril
- Domoticz version: latest
Re: Domoticz App
hmmmm do you use http with a valid certificate??DewGew wrote: Wednesday 08 April 2020 21:01I have same problem. I had to remove the app then install it again. But when I activated security setup it crashed again. Now I reinstalled it without activate security it works.vgr2 wrote: Wednesday 08 April 2020 18:47 Latest App Version is not working on my iOS 13.4.1.
Can you maybe make screenshots of what you mean? with security setup etc?
Domoticz Android app:
https://play.google.com/store/apps/deta ... s.domoticz
- galadril
Re: Domoticz App
Good oneFearNaBoinne wrote: Wednesday 08 April 2020 20:58 The Github says it's not available on Apple's AppStore yet because it is still beta... But the site links to the App on Appstore...![]()
- DewGew
Re: Domoticz App
Yes i have a valid certificategaladril wrote: Thursday 09 April 2020 20:21hmmmm do you use http with a valid certificate??DewGew wrote: Wednesday 08 April 2020 21:01I have same problem. I had to remove the app then install it again. But when I activated security setup it crashed again. Now I reinstalled it without activate security it works.vgr2 wrote: Wednesday 08 April 2020 18:47 Latest App Version is not working on my iOS 13.4.1.
- B3845FBD-8BCF-4684-B42B-9726FABE020E.png (131.81 KiB) Viewed 6855 times
Re: Domoticz App
I have the paid app and the server change does not work for me in the new version of the app. I have cleared cache of the app and if I create a separate server with the lan, if it works for me. Could you fix it? Thank you
- galadril
Re: Domoticz App
- galadril
Re: Domoticz App
Fixed the issue on beta.. is going to be in the next releasegaladril wrote: Saturday 11 April 2020 23:14Created an issue to keep track
https://github.com/domoticz/domoticz-xamarin/issues/22
- galadril
Re: Domoticz App
New update is coming on the app store that fixes the startup crash and adds the humidity percentage also on screen
- galadril
Re: Domoticz App
The new version is available in the App Store.. this should be fixedDewGew wrote: Thursday 09 April 2020 22:28Yes i have a valid certificategaladril wrote: Thursday 09 April 2020 20:21hmmmm do you use http with a valid certificate??DewGew wrote: Wednesday 08 April 2020 21:01
darrepac
Re: Domoticz App
I gave a new try to the app (iOS)
I put server information, not so sure what to put if http or https but I tried both (http was better working)
Then, at the next page, there is "check your parameters" (well it is in french for me so that could differ slightly)
I press the button and I got "not possible to get switches"
How to debug that??
How to debug that??
- galadril
Re: Domoticz App
We're working on a Geofencing and NFC version btw
- galadril
Re: Domoticz App
There is an issue with your connection settings.darrepac wrote: Wednesday 15 April 2020 10:02 I put server information, not so sure what to put if http or https but I tried both (http was better working)
You could hit the 'use demo' button, just to see if the settings you're entering are in the right format.
And your using an account in Domoticz that has enough rights to see devices right?
Edit > I may have found an issue in that app in the code that checks if your on your local or remote....
https://github.com/domoticz/domoticz-xamarin/issues/25
darrepac
Re: Domoticz App
Yesgaladril wrote: Thursday 16 April 2020 8:12 And your using an account in Domoticz that has enough rights to see devices right?
- galadril
Re: Domoticz App
Its now possible to join the beta testing via public url:
https://testflight.apple.com/join/z9WzSVkS
I've also set this beta join link on my website https://www.hnogames.nl/domoticz.html and on the first post of this thread
- galadril
Re: Domoticz App
I've submitted a new beta with some fixes on the local/remote detecting method.
beta version 0.1.11 (still needs to be reviewed by Apple)
- galadril
Re: Domoticz App
BTW the first tests with Geofences and NFC in the field look good so far..
- galadril
Re: Domoticz App
I've also uploaded the first beta with iBeacon support and App Shortcuts (quick links)
- solidum90
- Domoticz version: Debian
Re: Domoticz App
Hello, I’ve a problem since last weeks updates Borghi on Apple store app (I’ve bought pay version) and beta version.
The search button on top right doesn’t work, the search box does not appear.
Thanks for your work!
- galadril
Re: Domoticz App
What iOS version do you use?solidum90 wrote: Sunday 26 April 2020 14:40 Hello, I’ve a problem since last weeks updates Borghi on Apple store app (I’ve bought pay version) and beta version.
Thanks for your work!![]()
