hello,
in the wiki we find that in the Nederlands, you can connect your "Toon" from Eneco to Domoticz by default:
https://www.domoticz.com/wiki/Toon
but in Belgium, we have "boxx" from Engie (https://www.engie.be/nl/slimme-thermostaat/) :
witch is exactly the same thermostat, even with the same UI, but the connection with Domoticz doesn't work.
does anybody know the difference between the two?
thanks in advance
Toon Thermostat VS Boxx Thermostat
LaurentVDP
- Domoticz version: 2020.1
Domoticz 2020.1 on Rasberry Pi 4B
Sonos speakers |
Sonos speakers |
tobydeteckel
- Domoticz version: V12461
Re: Toon Thermostat VS Boxx Thermostat
the website where you login with this Hardware plugin isnt supported by Eneco enymore you could try using the ToonApiLib plugin using developers API.
this is the new way domoticz can interact with toon.
i do have toon myself, since 2015, last december i did root the device this was overall the best. maby also an option for you?
