wouldn't it be a good idea to check if the version of the db that we try to upload is compatible with the actual Domoticz instance?
Right now it's possible to load a newer version of the db into an older instance causing Domoticz to crash.
Edit: I've inverted newer/older
Check db version compatibility before restore
