I updated today to the latest version (also latest beta).
But on startup I still get message: (iDetect) Missing paramiko module required for ssh. Install it using: sudo pip3 install paramiko
If you update python then you will have to reinstall the required modules for that python version. Python does not automatically install the modules for the newer version.
Edit: You already tried that... so you are probably using separate python environments and have to make sure you are in the 3.6 environment when doing the pip3 install
2020-04-12 23:40:08.683 Status: (Presense) Started.
2020-04-12 23:40:08.839 Status: (Presense) Entering work loop.
2020-04-12 23:40:08.840 Status: (Presense) Initialized version 2.0, author 'ESCape'
2020-04-12 23:40:09.385 (Presense) Debug logging mask set to: PYTHON
2020-04-12 23:40:09.385 (Presense) Operation system is: linux
2020-04-12 23:40:09.397 (Presense) The OS user profile running domoticz is: root
2020-04-12 23:40:09.397 (Presense) Parsing user and optional keyfile from:radar
2020-04-12 23:40:09.398 (Presense) start get or create wireless device
2020-04-12 23:40:09.398 (Presense) phone1 monitor tag_id:98:87:E0:2E:18:2A, domoticz unit:2
2020-04-12 23:40:09.398 (Presense) phone2 monitor tag_id:88:6B:6E:5A:ED:A1, domoticz unit:3
2020-04-12 23:40:09.398 (Presense) Monitoring {'98:87:E0:2E:18:2A': <plugin.tag_device object at 0xa315af90>, '88:6B:6E:5A:ED:A1': <plugin.tag_device object at 0xa3165410>} for presence.
2020-04-12 23:40:09.398 (Presense) Tracker configuration:192.168.24.10
2020-04-12 23:40:09.398 (Presense) tracker:192.168.24.10
2020-04-12 23:40:09.398 (Presense) options:
2020-04-12 23:40:09.399 (Presense) 192.168.24.10 Tracker is of the ssh kind
2020-04-12 23:40:09.399 (Presense) 192.168.24.10 ====> SSH Fetching data using:
2020-04-12 23:40:09.399 export PATH=/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:$PATH
2020-04-12 23:40:09.399 type wl
2020-04-12 23:40:09.399 type iwinfo
2020-04-12 23:40:09.399 type wlanconfig
2020-04-12 23:40:09.399 type wl_atheros
2020-04-12 23:40:09.399 type qcsapi_sockrpc
2020-04-12 23:40:09.399 type ip
2020-04-12 23:40:09.399 type brctl
2020-04-12 23:40:09.399 type arp
2020-04-12 23:40:09.399 [ -f /proc/net/arp ] && type cat
2020-04-12 23:40:09.399 echo 0
2020-04-12 23:40:09.399 exit
2020-04-12 23:40:09.399 (Presense) 192.168.24.10 ====> SSH not connected ... connecting
2020-04-12 23:40:09.399 (Presense) 192.168.24.10 ====> SSH start connect
2020-04-12 23:40:09.736 (Presense) 192.168.24.10 Could not retreive available commands
2020-04-12 23:40:09.736 (Presense) 192.168.24.10 tracker will autodetect ssh cli
2020-04-12 23:40:09.736 (Presense) 192.168.24.10 Data will be received and interpreted by <bound method BasePlugin.onDataReceive of <plugin.BasePlugin object at 0xa8840870>>
2020-04-12 23:40:09.736 (Presense) Trackers initialized as:{'192.168.24.10': <trackers.ssh_autodetect.ssh_autodetect object at 0xa31658d0>}
2020-04-12 23:40:09.736 (Presense) Plugin initialization done.
2020-04-12 23:40:09.736 Status: (Presense) Tracker activated:192.168.24.10 port 22, user: radar, type: default and options: {}
2020-04-12 23:40:09.736 Error: (Presense) 192.168.24.10 ====> SSH Could not connect (using password). Exception: Authentication failed.
Microtik can not be auto detected because it uses a proprietary operating system called routerOS. The plugin offers support for routeros, by specifying the tracker type:
Geitje wrote: Monday 13 April 2020 20:59
When I disable debugging after having it enabled for some time, Domoticz hangs? Anyone else with this problem?
Domoticz might hang if a connection was not closed (in time) while shutting down a plugin. Changing any setting will restart the plugin. Maybe it takes longer than usual to terminate the connection in your setup. Your original post said you where seeing time-outs on poll-connections. Has this been solved and are you sure Domoticz is still hanging when stopping/restaring the plugin?
Thanks for you reply. Domoticz restarts fine, and the hangs happens not always.
Yeah the time-outs are still coming sometimes quite a lot. The delay for devices going to offline for is acceptable: about 8 mins.
However, I still think the Orbi sometimes needs some more time to answer the requests, more than 8 secs. I know from the Orbi webUI that the router needs quite a long time to build the device list (like 10 seconds or more). The number of LAN devices I have has increased past months. Also I started to use a feature called Netgear Armor, that also uses processing power from the Orbi. Would it be possible to make the time-out configurable?
Zwave, Zigate, RFlink etc.
In addition there are two alternative tracker types:
routeros-arp and routeros-capsman (requires capsman installed on router)
Have the same error:
2020-04-15 11:49:19.061 Error: (Presense) 192.168.24.10 ====> SSH Could not connect (using password). Exception: Authentication failed.
But i can login to microtik from rapberry pi with these creditionals
- from root shell
-from pi shell
- from root shell
-from pi shell
Strange ... can you try setting a tracker specific password this way:
Other things to check out:
- Remove any special characters from the routers ssh password (to rule them out as a possible cause)
- Some routers only allow specific usernames to connect to ssh, like 'admin'
Geitje wrote: Wednesday 15 April 2020 10:00
It would be great if someone who actually uses an Orbi could troubleshoot this. Maybe the tracker need some more error handling or there might even be a better way to query an orby(?)
Could you try increasing the hard coded timeout in the plugin code? It's on line 20 of http_orbi.py (but I guess you already knew that;-))
If a longer timeout solves this issue, then it still might not be the best solution to permanently increase it. A lot of waiting connections could cause Domoticz to hang when trying to stop the plugin.
Hi, first of all, I like this plugin very much as it seems more reliable then the other scripts (well, at least in my home). The thing is, I keep getting errors starting somewhere during the night:
2020-04-16 08:10:11.983 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:17.370 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:21.993 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:27.384 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:32.005 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:37.392 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:42.017 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:47.398 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:52.042 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:10:57.407 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:11:02.083 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:11:12.432 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:11:17.119 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:11:27.465 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:11:32.166 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:11:42.505 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:11:47.203 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:11:57.537 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:12:02.227 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:12:07.545 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:17.244 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:12:17.550 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:27.266 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:27.568 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:37.285 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:42.595 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: No existing session
2020-04-16 08:12:47.291 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:52.614 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:12:57.298 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:02.626 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:07.304 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:12.631 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:17.309 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:22.636 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:27.314 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:32.644 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:37.319 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:42.656 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:47.323 Error: (iDetect) 10.10.10.111 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
2020-04-16 08:13:52.661 Error: (iDetect) 10.10.10.110 ====> SSH Could not connect (using password). Exception: Error reading SSH protocol banner
Automatically restarting the plugin using the "Data Timeout" setting, doesn't fix it. Updating the plugin settings (without actually changing anything) does.
Is this a known error with (hopefully) a known workaround?
Ray-Man wrote: Thursday 16 April 2020 8:38
Regards.
It is not a known issue and 'Error reading SSH protocol banner' is a generic error which could mean anything. The "data timeout" will not affect to ssh connections, so you can leave that off.
There are a few tings you can check/try to trouble shoot.
- is there more information in the (debug) log around the time these errors start appearing? (these errors in the morning might be a symptom instead of a cause)
- is there a heavy network load or cpu load on the raspberry or router at night?
- are there (maintenance) tasks that reset network interfaces of services in the raspberry, router or network?
- set the poll interval a bit higher for a couple of days. Do the problems go away? Then maybe something is getting overloaded with waiting connections (if it takes > 10 seconds do do something every 10 seconds ...)
I wil try this sometime next week, and report back! Right now I have 25-30 time-outs reported a day, I will check it will be less when time-out increases.
EscApe wrote: Thursday 16 April 2020 7:01
- from root shell
-from pi shell
unfortunately did not help =(
Ok. Thanks for response, i think i'll use scripts on microtik side.
I installed/configured the plugin last wednesday. In the night to thursday my Domoticz became unresponsive because of this.
Yesterday I decreased the poll to 10 min but still after a couple of hours SSH errors.
SSH Could not connect (using password). Exception: Authentication timeout.
It begins with SSH failed with exception: Timeout opening channel. and then every poll SSH Could not connect (using password). Exception: Authentication timeout.
I disabled the plugin so that my Domoticz still keeps working. Any idea why after a while it starts the SSH time out issues?
eleutscher wrote: Friday 17 April 2020 11:42
I have never seen these timeouts in my setup, but there was another similar report recently. Maybe something has changed in Domoticz/linux/paramiko??
Can you provide the following information, so I can investigate?
- Router make and model and firmware version
- Domoticz version
- Linux Version
- Python and Paramiko version
A debug log might also offer more information
I've written some code to make iDetect work with the TP-link Omada WiFi controller. I've successfully tested it against Omada version 3.2.6 on Linux.
Note that although newly connected devices are detected quickly, devices that disconnect from WiFi remain up to 5 minutes in the Omada clients table for some reason. This is an Omada thing and I haven't found a solution for it yet.
