Script to import CumulusMX Data from an http call
bigmacd
Post by bigmacd »
I have a weather station sitting on an old Raspberry Pi B running CumulusMX.
The following call returns all the output data:
http://<ip>:8998/api/data/currentdata
Quite a lot of information:
{"AlltimeHighPressure":"1043.6","AlltimeLowPressure":"981.0","AppTemp":"2.8","AvgTempToday":3.9326086956521555,"Avgbearing":140,"Bearing":180,"BearingRangeFrom10":130,"BearingRangeTo10":180,"Build":"3036","Cloudbase":496,"CloudbaseUnit":"ft","CurrentSolarMax":0,"DataStopped":false,"DominantWindDirection":"SE","Forecast":"Showery, becoming less settled","HeatIndex":"7.3","HighAppTempToday":"4.6","HighAppTempTodayTime":"12:26","HighBeaufortToday":"F3","HighDewpointToday":"6.1","HighDewpointTodayTime":"17:32","HighGustBearingToday":135,"HighGustToday":"16","HighGustTodayTime":"17:35","HighHeatIndexToday":"9.0","HighHeatIndexTodayTime":"12:25","HighHourlyRainToday":"0.0","HighHourlyRainTodayTime":"00:06","HighHumToday":92,"HighHumTodayTime":"09:06","HighPressToday":"1024.3","HighPressTodayTime":"00:56","HighRainRateToday":"0.0","HighRainRateTodayTime":"00:06","HighSolarRadToday":0,"HighSolarRadTodayTime":"00:06","HighTempToday":"9.0","HighTempTodayTime":"12:25","HighUVindexToday":"0.0","HighUVindexTodayTime":"00:06","HighWindToday":"12","Humidex":"7.0","IndoorHum":68,"IndoorTemp":"12.5","LastDataRead":"17:42:59","LastRainTipISO":"2016-02-17 14:38","LowAppTempToday":"-2.8","LowAppTempTodayTime":"06:16","LowDewpointToday":"-2.2","LowDewpointTodayTime":"04:46","LowHumToday":71,"LowHumTodayTime":"12:26","LowPressToday":"1014.2","LowPressTodayTime":"17:18","LowTempToday":"0.4","LowTempTodayTime":"04:46","LowWindChillToday":"-1.3","LowWindChillTodayTime":"06:16","Moonrise":"14:21","Moonset":"05:09","OutdoorDewpoint":"6.1","OutdoorHum":92,"OutdoorTemp":"7.3","PressTrend":"-1.2","PressUnit":"mb","Pressure":"1014.4","RainLastHour":"0.0","RainMonth":"57.3","RainRate":"0.0","RainToday":"0.0","RainUnit":"mm","RainYear":"125.1","RainYesterday":"0.0","Recentmaxgust":"16","SolarRad":0,"StormRain":"0.0","StormRainStart":"-----","Sunrise":"07:19","Sunset":"17:31","SunshineHours":"0.0","TempTrend":"-0.1","TempUnit":"°C","UVindex":"0.0","Version":"3.0.0","WindAverage":"11","WindChill":"4.1","WindLatest":"12","WindRoseData":"0,0,46,0,712,1061,10336,521,4638,0,220,1,0,0,0,0","WindRunToday":"100.4","WindUnit":"mph"}
I have written the following code to update a few idxs: (first go at lua and not pretty!)
print("Load CMX data ".._VERSION.."=".."!\n")
local idxthp = 32 --idx of the virtual sensor you need to change this to your own Device IDx
local idxt = 30
local idxh = 31
--if devicechanged[sensorwu] then
if true then
        -- create file of values from CumulusMX (Change IP address to suit your system)
        os.execute('curl "http://<ip>:8998/api/data/currentdata" > /home/pi/CMX.txt')
        -- one long line
        for line in io.lines("/home/pi/CMX.txt") do
                t = {}
                s = line
                -- find value pairs on pattern match
                for k, v in string.gmatch(s, '(%w+)":"(%w+)') do
                        -- Load array of values keyed by the value name
                        t[k] = v
                        -- undo rem line below to print all values to the log
                        -- print(k.."="..v)
                for k, v in string.gmatch(s, '(%w+)":(%w+)') do
                        t[k] = v
                        -- print(k.."="..v)
                varstr="WindRunToday"
                --print(varstr.."="..t[varstr].."miles")
        --TEMP;HUM;HUM_STAT;BAR;BAR_FOR
        IndoorTemp=t["IndoorTemp"]
        IndoorHum=t["IndoorHum"]
        Pressure=t["Pressure"]
        PressTrend=t["PressTrend"]
        print(IndoorTemp,IndoorHum,Pressure,PressTrend)
        commandArray[1] = {['UpdateDevice'] = idxt .. '|0|' .. IndoorTemp}
        commandArray[2] = {['UpdateDevice'] = idxh .. '|' .. IndoorHum .. "|0" }
        commandArray[3] = {['UpdateDevice'] = idxthp .. '|0|' .. IndoorTemp .. "|" .. IndoorHum .. "|0|" .. Pressure .. "|0" }
If anyone is interested I would be pleased for some help improving this.
What are the humidity and weather devices looking for in the 0 place holders?
I know the file handling is poor and there must be a better way of loading the t[] array given the nature of the data.
All advice much appreciated.
TXs to the author of the weather Underground parser for many ideas. :)
RFXtrx433E
Raspberrypi 2
MAX EQ3
GPIO
Homeeasy
Mercury
CumulusMX
hve22
Re: Script to import CumulusMX Data from an http call
Post by hve22 »
At the momemt i'm looking for a script to get my CUMULUSMX data into Domoticz,
SO i came across your solution.
Question: Did you upgraded you script and if so can you share this??
With regards
bewo
Domoticz version: 2021.1
Post by bewo »
I think the output shown is an "normal" json string. So it's no problem to read and update devices. The script above has to be updated urgent. An "if true" argument is - in my opinion - an "programming ghost train".
What informations should be updated? Only temperature, humidity and pressure as in the script above?
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
