dew point & calendar not showing
- jjnh
- Domoticz version: 2023.1
Re: dew point & calendar not showing
The issue is not solved for me. My google calendar link is not working since 5 days. I tried the URL and that downloads a basic.ics file. The timezone in the file is "Europe/Amsterdam". Any ideas why it's not working anymore?
Odroid N2+ 4GB, with an RfxTrx433E, Zigbee with Slaesh's CC2652RB, Z-Wave, BroadLink IR using RM mini 3 and P1 connected.
- jjnh
Found it. I was running PHP 7.033 on the Apache server. After upgrading to PHP 7.4 and connecting is to my Apache2 the calendar was working again.
- Target OS: -
lzwfkv wrote: ↑Tuesday 31 March 2020 11:32You likely have an outstanding TimeZone String in your ical file (.ics) that the calendar library used by Dashticz is not able to recognize as a valid TimeZOne. Try to download the .ics file of your calendar and look for the TimeZones used in there, compare them with the Timezones in /home/pi/dashticz/vendor/dashticz/ical/vendor/om/icalparser/src/WindowsTimezones.php file. If you find any of them missing in the WindowsTimezones.php file, then that-s it. In that case, a quick workaround can be to add to the WindowsTimezones.php file a reasonable Timezone mapping for your ical timezone.Ybuqc wrote: ↑Tuesday 31 March 2020 0:10 Hello,
I have a similar problem. Calendar is not loading. Can't tell for preivous version as it is my first installation of Dashticz (which is fantastic by the way!).
When I tried the
"./vendor/dashticz/ical/?time=1585600958180&maxitems=6&url=MY_CALENDAR_URL", I got the followingCode: Select all
JSON: SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
RAW DATA: InvalidArgumentException: Invalid ICAL data format in /home/pi/dashticz/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php:65 Stack trace: #0 /home/pi/dashticz/vendor/dashticz/ical/vendor/om/icalparser/src/IcalParser.php(46): om\IcalParser->parseString('\n<!DOCTYPE html...', NULL) #1 /home/pi/dashticz/vendor/dashticz/ical/index.php(50): om\IcalParser->parseFile('https://calenda...') #2 {main}
For instance in my case i had 'Customized Time Zone' as timezone in one of my calendar events (it is a Microsoft Office 365 calendar - Exchange) and i had to map it to 'Europe/Berlin'.
I found Europe/Brussels, Africa/Ceuta (???)
So I have to add more entries like
'(UTC+01:00) Brussels' => 'Europe/Brussels',
'(UTC+01:00) Ceuta' => 'Africa/Ceuta',
For new mappings, on the left of '=>' you must type your ical event timezone and on the right a know (conventional) timezone name which is known to the library, as much as possible coherent with your .ics timezone.
Therefore, if in your .ics you have TZID=Europe/Brussels and TZID=Africa/Ceuta, none of them is already known to the library and you should map both to Europe/Paris.
So, let's try this way:
make a backup of the original WindowsTimezones.php file.
edit WindowsTimezones.php and append these lines to the exisiting Timezone mappings list:
'Europe/Brussels' => 'Europe/Paris',
'Africa/Ceuta' => 'Europe/Paris',
Hope this helps.
Hope this helps.
- Target OS: -
thanks for the explanation, lzwfkv
too bad it doesn't help
Check that you are using exactly the same timezone naming at the left of the '=>' symbol as in the ics file. Maybe you have to use:
'(UTC+01:00) Brussels' => 'Europe/Paris',
'(UTC+01:00) Ceuta' => 'Europe/Paris',
- Target OS: -
@Lokonli,
the dew point now shows values like '1.69', maybe better if that would be '2'?
if (typeof (device['DewPoint']) !== 'undefined') {
if (single_block) {
blockValues[0].value += ' / ' + Math.round(device['DewPoint']) + ' °';
} else {
blockValues.push({
icon: 'wi wi-fog',
idx: idx + '_4',
title: device['Name'],
value: Math.round(device['DewPoint']),
unit: _TEMP_SYMBOL
Are you willing to make the changes yourself? If you make a Pull Request (PR) I'll merge the changes.
I've documented the way of working here:
https://dashticz.readthedocs.io/en/beta ... b-workflow
If that sounds too challenging, then I'll make the change
- Target OS: -
OK, I'll have a look tonight
- Target OS: -
@Lokonli, I'm having trouble with point 10 in the documentation git push mynewfeature
So I used git push dewpoint1decimal, but I get an error;
fatal: 'dewpoint1decimal' does not appear to be a git repository
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Probably you have to use:
I will adapt the documentation.
git push origin dewpoint1decimal
- Target OS: -
OK, I hope it's finished
Thanks for your contribution. Well done!
Could you test latest beta? (There are more changes ...)
- Target OS: -
you're welcome.
Glad to learn something new.
new beta: the title of those blocks is gone
before:
problem with calendar still exists so I set debug to 1 again.
also, I have a Hue Go block. The colour selector is gone, just the small arrow, and the slider is sticking to the bottom of the block.
<div class="col-xs-8 col-data">
<strong class="title">11,4 °C</strong><br>
<span class="value">THB</span>
</div>
<strong class="title">Temperatuur</strong><br>
<span class="value">11,4 °C</span>
</div>
