Zigate error with plugin version pre-4.1
geertvercamer
Re: Zigate error with plugin version pre-4.1
Post by geertvercamer »
I can't get the plugin to work.
Domoticz is running on W10
I keep getting these errors:
2020-04-01 20:47:17.728 Status: (Zigate) Zigate plugin beta-4.8.008 started
2020-04-01 20:47:17.728 Status: (Zigate) Debug: 30
2020-04-01 20:47:17.732 Status: (Zigate) load PluginConf
2020-04-01 20:47:17.733 Error: (Zigate) 'onStart' failed 'PermissionError'.
2020-04-01 20:47:17.733 Error: (Zigate) ----> Line 898 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\plugin.py'
2020-04-01 20:47:17.733 Error: (Zigate) ----> Line 233 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\plugin.py'
2020-04-01 20:47:17.733 Error: (Zigate) ----> Line 247 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Classes\PluginConf.py'
2020-04-01 20:47:17.733 Error: (Zigate) ----> Line 298 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Classes\PluginConf.py'
2020-04-01 20:47:17.734 Error: (Zigate) ----> Line 355 in 'C:\Program Files (x86)\Domoticz\plugins\Domoticz-Zigate\Classes\PluginConf.py'
Thanks for any help
pipiche
Post by pipiche »
geertvercamer wrote:Hi,
Thanks for any help
Could you please list all files and folder below Domoticz-Zigate
geertvercamer
sure:
Classes <DIR>
Conf <DIR>
CONTRIBUTING.md
Data <DIR>
dns <DIR>
images <DIR>
LICENSE.txt
Logs <DIR>
MANIFEST.in
Modules <DIR>
OTAFirmware <DIR>
plugin.py
readme.md
ReleaseNotes.md
Reports <DIR>
Tools <DIR>
www <DIR>
Zigate-Firmware <DIR>
pipiche
Post by pipiche »
geertvercamer wrote:sure:
Classes <DIR>
Conf <DIR>
CONTRIBUTING.md
Data <DIR>
dns <DIR>
images <DIR>
LICENSE.txt
Logs <DIR>
MANIFEST.in
Modules <DIR>
OTAFirmware <DIR>
plugin.py
readme.md
ReleaseNotes.md
Reports <DIR>
Tools <DIR>
www <DIR>
Anything in the Conf folder ?
geertvercamer
yes,
folder Certified (containing more folders of brands)
DeviceConf.txt
pipiche
Post by pipiche »
geertvercamer wrote:yes,
DeviceConf.txt
I suspect that the plugin is not able to create a file which should be
Domoticz-Zigate/Conf/PluginConf-xx.json
Where xx is the hardwareId of the plugin
Is domoticz running with admin privileges ? What could prevent file creation ?
geertvercamer
running as a service with local system account. This is admin, right?
pipiche
Post by pipiche »
From the source code, the issue is Opening in creation mode a file named Domoticz-Zigate/Conf/PluginConf-xx.json
I'm not a Windows guy, so maybe the windows people could help here, but the message in the logs are clear
geertvercamer
there's no way to have the config files written anywhere else?
pipiche
Post by pipiche »
Conf is a must from the plugin code. Eventually you might create a file in this folder
Here after is an exemple of Conf/PluginConf-05.json
So for your , you need to check what is the HardwareID (this is available in Domoticz Hardware. The Id of the Zigate Hardware, padded with 0)
  "filename": "/var/lib/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-05.json",
  "homedirectory": "/var/lib/domoticz/plugins/Domoticz-Zigate/",
  "pluginConfig": "/var/lib/domoticz/plugins/Domoticz-Zigate/Conf/",
  "pluginData": "/var/lib/domoticz/plugins/Domoticz-Zigate/Data/",
  "pluginHome": "/var/lib/domoticz/plugins/Domoticz-Zigate/",
  "pluginLogs": "/var/lib/domoticz/plugins/Domoticz-Zigate/Logs/",
  "pluginOTAFirmware": "/var/lib/domoticz/plugins/Domoticz-Zigate/OTAFirmware/",
  "pluginReports": "/var/lib/domoticz/plugins/Domoticz-Zigate/Reports/",
  "pluginWWW": "/var/lib/domoticz/plugins/Domoticz-Zigate/www/"
geertvercamer
Well, this helped A LOT!
Thanks.
I first tried to set all these to 'C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\' but still got an error on writing Zigate.json.
There may be a / too much in Modeles/database.py on line 272.
        json_filename = self.pluginconf.pluginConf['pluginData'] + "/Zigate.json"
I removed it but eventually also had to modify so the data and logs are written to a folder out of '\Program Files\....'
Thanks a million.
pipiche
Post by pipiche »
So you mean that if we remove the / in database.py line 272, it fixes the problem ?
Would you mind to attach the PluginConf-xx.json, so I'll put it in the distribution as a ref for Windows users
geertvercamer
sorry for the delay.
I first tried to map all the entries in PluginConf-xx.json to "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\"
It took me a few steps further but got the error that it couldn't access c:\program files...\Domoticz-Zigate\/Zigate.json.
Mind the extra /
I tracked it to line 272 where the setting is used "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\Data\\" + "/Zigate.json"
In your example, all the settings have end in '/' (need converting to \\ in Windows), so on line 272 you would get:
"/var/lib/domoticz/plugins/Domoticz-Zigate/Data/" + "/Zigate.json"
"/var/lib/domoticz/plugins/Domoticz-Zigate/Data//Zigate.json"
Maybe that doesn't throw an error in Linux, I don't know, I'd say there's no need for the '/' on line 272. Definitely not on Windows
Finally I had to move the pluginData and pluginLogs to another place as there were still problems with write rights.
PluginConf-xx.json:
  "filename": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\Conf\\PluginConf-19.json",
  "homedirectory": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\",
  "pluginConfig": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\Conf\\",
  "pluginData": "D:\\DomoticzExtra\\Zigate\\Data\\",
  "pluginHome": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\",
  "pluginLogs": "D:\\DomoticzExtra\\Zigate\\Logs\\",
  "pluginOTAFirmware": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\OTAFirmware\\",
  "pluginReports": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\Reports\\",
  "pluginWWW": "C:\\Program Files (x86)\\Domoticz\\plugins\\Domoticz-Zigate\\www\\"
pipiche
Post by pipiche »
Make sure to run Domoticz with Administrator rights
Screenshot 2020-06-29 at 19.57.48.png (286.66 KiB) Viewed 1003 times
