Update from v3.3.3.1 (stable) to v3.4.1 (beta)
florisi
- Domoticz version: 2020beta
I'm running dashticz stable on my ubuntu server.
Wanna upgrade to v3.4.1 beta
How can I upgrade to the last beta?
Alfagek
- Domoticz version: 2020.1
Re: Update from v3.3.3.1 (stable) to v3.4.1 (beta)
git checkout beta
git pull-
florisi
Thanks, works.
But still have the problem with the Mi Flower.
Lokonli
Normally we are pretty quick in answering issues, but we can't address all requests within one day.
If you want to help, you are more than welcome.
Anyway, to add Mi Flower support, replace the function getExtendedBlockTypes in custom/custom.js with the following:
You should get two devices: The moisture value, and the irrigation advice.
Please confirm whether this is working, and I'll merge it in the next beta release.
function getExtendedBlockTypes(blocktypes){
blocktypes.SubType['Soil Moisture'] = {}
blocktypes.SubType['Soil Moisture']['cb'] = {
icon: 'fas fa-seedling',
title: '<Name>',
value: '<Data>',
blocktypes.SubType['Soil Moisture']['advice'] = {
title: '<Name>',
value: '<Desc>',
return blocktypes;
florisi
Replaced custom.js with the snippet, now the devices are disappeared. (not working)
Here is my current custom.js
//add custom javascript in here
function afterGetDevices(){
title: '<Name>',
value: '<Data>',
title: '<Name>',
value: '<Desc>',
return blocktypes;
function getStatus_98(idx,value,device) {
if(parseFloat(device['Data'])>1000) {
$('div.block_98').addClass('warning');
} else {
$('div.block_98').removeClass('warning');
function getStatus_100(idx,value,device) {
$('div.block_100').addClass('warning');
} else {
$('div.block_100').removeClass('warning');
Lokonli
In 3.4.1 beta the interface of the getStatus functions changed. See the following link for some examples:
https://dashticz.readthedocs.io/en/beta ... fterupdate
replace the functions with the following code block:
function getStatus_98(block) {
var device=block.device;
block.addClass='warning';
} else {
block.addClass='';
florisi
thanks for the update, but still not working.
The Mi Flower doesn't appear.
Here is the custom.js again.
title: '<Name>',
value: '<Data>',
title: '<Name>',
value: '<Desc>',
return blocktypes;
} else {
block.addClass='';
function getStatus_100(block) {
} else {
block.addClass='';
Lokonli
The other blocks are displayed correctly?
Can you open DevTools in Chrome by pressing F12.
Then open or refresh Dashticz.
In Devtools go to the console tab. Do you see any error?
florisi
I have this error:
TypeError: (title + value).match is not a function
at getStatusBlock (js/blocks.js:897)
at handleDevice (js/blocks.js:1342)
at deviceUpdateHandler (js/blocks.js:394)
at js/blocks.js:448
at ListObservable.subscribe (js/domoticz-api.js:421)
at Object._subscribe [as subscribe] (js/domoticz-api.js:342)
at addDeviceUpdateHandler (js/blocks.js:446)
at getBlock (js/blocks.js:307)
at buildScreens (<anonymous>:457:29)
at onLoad (<anonymous>:241:5)-
Lokonli
I think I've found the issue.
Try the following in custom.js for the getExtendedBlockTypes function:
title: '<Name>',
value: '<Data> <Desc>',
return blocktypes;
florisi
that's working.
The device shows:
41 cb irrigation advise.
The device shows:
Lokonli
Good. Time to water the plantsflorisi wrote: Wednesday 01 April 2020 21:18 that's working.
The device shows:
Apparently subdevices cannot be generated from a SubType device block at the moment, but that can be changed.
Do you prefer one or two devices?
florisi
I prefer two devices if it. is not to much work.
Will check tomorrow.
Gianni
how can i upgrade from this.
my version is 3.3.4 beta
git checkout beta
Already on 'beta'
Your branch is up to date with 'origin/beta'.
gianni@domotic:/var/www/html/homecontrol $ git pull
Already up to date.
git checkout beta
Already on 'beta'
Already up to date.
Lokonli
What do you get with:
git remote -v
Gianni
@lokonli you was faster then me
was already testing
was already testing
gianni@domotic:/var/www/html/homecontrol $ git remote -v
origin https://github.com/dashticzv3/dashticz_v3 (fetch)
origin https://github.com/dashticzv3/dashticz_v3 (push)
gianni@domotic:/var/www/html/homecontrol $ git status
On branch beta
Changes not staged for commit:
(use "git add <file>..." to update what will be committed)
(use "git checkout -- <file>..." to discard changes in working directory)
[code]-
Lokonli
You are using my old repository...
git remote set-url origin https://github.com/Dashticz/dashticz
git pull
Gianni
1 step + but abort error now
remote: Enumerating objects: 646, done.
remote: Counting objects: 100% (646/646), done.
remote: Compressing objects: 100% (106/106), done.
remote: Total 2610 (delta 567), reused 585 (delta 538), pack-reused 1964
Receiving objects: 100% (2610/2610), 13.66 MiB | 5.72 MiB/s, done.
Resolving deltas: 100% (1729/1729), completed with 81 local objects.
From https://github.com/Dashticz/dashticz
68a376c..6b4374a beta -> origin/beta
* [new branch] blocks -> origin/blocks
* [new branch] dependabot/npm_and_yarn/acorn-6.4.1 -> origin/dependabot/npm_and_yarn/acorn-6.4.1
+ 11e431f...e67ca60 master -> origin/master (forced update)
* [new tag] v3.0.0 -> v3.0.0
* [new tag] v3.0.3-beta -> v3.0.3-beta
* [new tag] v3.0.4-beta -> v3.0.4-beta
* [new tag] v3.0.5 -> v3.0.5
* [new tag] v3.0.6 -> v3.0.6
* [new tag] v3.0.6-beta -> v3.0.6-beta
* [new tag] v3.1.0-beta -> v3.1.0-beta
* [new tag] v3.1.1-beta -> v3.1.1-beta
* [new tag] v3.1.2 -> v3.1.2
* [new tag] v3.3.2 -> v3.3.2
* [new tag] v3.3.3 -> v3.3.3
* [new tag] v3.3.4-beta -> v3.3.4-beta
* [new tag] v3.4.1-beta -> v3.4.1-beta
Updating 68a376c..6b4374a
error: Your local changes to the following files would be overwritten by merge:
.gitignore
Dockerfile
Makefile
README.md
css/creative.css
docs/blocks/blocks.rst
docs/blocks/buttons.rst
docs/blocks/domoticzblocks.rst
docs/blocks/frames.rst
docs/blocks/specials/calendar.rst
docs/blocks/specials/garbage.rst
docs/blocks/specials/news.rst
docs/blocks/specials/publictransport.rst
docs/blocks/specials/streamplayer.rst
docs/blocks/specials/trafficinfo.rst
docs/blocks/specials/tvguide.rst
docs/blocks/specials/weather.rst
docs/customcss/customcss.rst
docs/customjss/customjss.rst
docs/dashticzconfiguration.rst
docs/develop/code.rst
docs/develop/documentation.rst
docs/gettingstarted/automaticinstall.rst
docs/gettingstarted/basicdashboard.rst
docs/gettingstarted/manualinstall.rst
docs/index.rst
docs/releasenotes.rst
docs/screens.rst
docs/tipsandtricks.rst
index.html
index2.html
js/blocks.js
js/calendar.js
js/chromecast.js
js/garbage.js
js/graphs.js
js/login.js
js/main.js
js/publictransport.js
js/settings.js
js/sonarr.js
js/switches.js
js/thermostat.js
js/version.js
js/weather_owm.js
lang/bs_BA.json
lang/ca_ES.json
lang/cs_CZ.json
lang/da_DK.json
lang/de_DE.json
lang/en_US.json
lang/es_ES.json
lang/fi_FI.json
lang/fr_FR.json
lang/hu_HU.json
lang/it_IT.json
lang/lt_LT.json
lang/nb_NO.json
lang/nl_NL.json
lang/nn_NO.json
lang/pl_PL.json
lang/pt_PT.json
lang/ro_RO.json
lang/ru_RU.json
lang/sk_SK.json
lang/sl_SI.json
lang/sr_RS.json
lang/sv_SE.json
lang/tr_TR.json
lang/uk_UA.json
lang/zh_CN.json
scripts/dashticz_install.sh
vendor/dashticz/ical/index.php
version.txt
Please commit your changes or stash them before you merge.
error: The following untracked working tree files would be overwritten by merge:
.babelrc
.eslintrc.js
.vscode/settings.json
babel.config.js
css/secpanel.css
dist/0724bb8b89ab6b8b9b7df917b17be0b7.svg
dist/57dcda6f368ea90179f75cbdae96c263.eot
dist/5d0861781aeef6c82fda3a3076954a1b.svg
dist/75f38a159982b6bd1704891332d95fa7.ttf
dist/89889688147bd7575d6327160d64e760.svg
dist/89e02bae13c9131c7468b1e729339ac1.eot
dist/9d67fa1429375bd2a899a17eb77d0342.svg
dist/9ec698d1a597bff5df337094b71ddaaf.ttf
dist/assets/images/ui-icons_444444_256x240.png
dist/assets/images/ui-icons_555555_256x240.png
dist/assets/images/ui-icons_777620_256x240.png
dist/assets/images/ui-icons_777777_256x240.png
dist/assets/images/ui-icons_cc0000_256x240.png
dist/assets/images/ui-icons_ffffff_256x240.png
dist/bundle.js
docs/blocks/graphs.rst
docs/blocks/img/climate.jpg
docs/blocks/img/climate_te_hu.jpg
docs/blocks/img/customlabels.jpg
docs/blocks/img/evohome.png
docs/blocks/img/graph_buttons1.png
docs/blocks/img/graph_buttons2.png
docs/blocks/img/graph_buttons3.png
docs/blocks/img/graph_buttons4.png
docs/blocks/img/graph_debug.jpg
docs/blocks/img/graph_groupby_day.png
docs/blocks/img/graph_zoom_x.jpg
docs/blocks/img/graph_zoom_x2.jpg
docs/blocks/img/group_by_device_1.png
docs/blocks/img/group_by_device_2.png
docs/blocks/img/group_by_device_3.png
docs/blocks/img/muligraph_patch4_1.png
docs/blocks/img/muligraph_patch4_2.png
docs/blocks/img/muligraph_patch4_3.png
docs/blocks/img/muligraph_patch4_4.png
docs/blocks/img/muligraph_patch4_5.png
docs/blocks/img/multigraph3.png
docs/blocks/img/multigraph4.png
docs/blocks/img/multigraph5.png
docs/blocks/img/multigraph6.png
docs/blocks/img/multigraph_button_styling.jpg
docs/blocks/img/multigraph_custom.png
docs/blocks/img/multigraph_point_styling.jpg
docs/blocks/img/multigraph_setpoints.png
docs/blocks/img/p1.jpg
docs/blocks/img/p1_custom.jpg
docs/blocks/img/p1_legend.jpg
docs/blocks/img/p1_legend_2.jpg
docs/blocks/img/solar_1_default.jpg
docs/blocks/img/solar_custom_legend.jpg
docs/blocks/img/solar_default.jpg
docs/blocks/img/solar_legend.jpg
docs/blocks/img/solar_yellow_bar.jpg
docs/blocks/img/water.jpg
docs/blocks/specials/img/calendar1.jpg
docs/blocks/specials/security_panel.rst
docs/blocks/specials/security_panel_block.jpg
docs/blocks/specials/security_panel_frame.jpg
docs/customcss/specialclasses.jpg
docs/customjs/customjs.rst
docs/img/dashticz-websocket.gif
docs/releasenotes/index.rst
docs/releasenotes/releasenotes.rst
docs/releasenotes/upgrading/upgrading.rst
docs/releasenotes/upgrading/v320.rst
font/Audiowide.eot
font/Audiowide.svg
font/Audiowide.ttf
font/Audiowide.woff
font/Digital.eot
font/Digital.svg
font/Digital.ttf
font/Digital.woff
img/curtainclosed.png
img/curtainopen.png
img/dishwasher_240px.png
img/dishwasher_off.png
img/dishwasher_on.png
img/evohome.png
img/hot_water_on.png
img/speaker_off.png
img/speaker_on.png
img/tv_off.png
js/components/blocktitle.js
js/components/button.js
js/components/frame.js
js/components/graph.js
js/components/longfonds.js
js/components/news.js
js/components/publictransport.js
js/components/secpanel.js
js/components/stationclock.js
js/components/streamplayer.js
js/components/traffic.js
js/components/trafficinfo.js
js/components/train.js
js/components/tvguide.js
js/dashticz.js
js/domoticz-api.js
package.json
sounds/arm.aac
sounds/arm.mp3
sounds/arm.ogg
sounds/disarm.aac
sounds/disarm.mp3
sounds/disarm.ogg
sounds/key.aac
sounds/key.mp3
sounds/key.ogg
sounds/wrongcode.aac
sounds/wrongcode.mp3
sounds/wrongcode.ogg
src/functions.js
src/index.js
src/templateengine.js
vendor/dashticz/ical/composer.json
vendor/dashticz/ical/composer.lock
vendor/dashticz/ical/ical5/SG_iCal.php
vendor/dashticz/ical/ical5/blocks/SG_iCal_VCalendar.php
vendor/dashticz/ical/ical5/blocks/SG_iCal_VEvent.php
vendor/dashticz/ical/ical5/blocks/SG_iCal_VTimeZone.php
vendor/dashticz/ical/ical5/helpers/SG_iCal_Duration.php
vendor/dashticz/ical/ical5/helpers/SG_iCal_Factory.php
vendor/dashticz/i
Aborting
Lokonli
Maybe better to start over, make a new clone from github and copy your previous CONFIG.js, custom.css and custom.js files.
Gianni
yep did that now
but still a error with garb....... :-p(offtopic try the auto install garb still not working)
