Update from v3.3.3.1 (stable) to v3.4.1 (beta)
florisi
Domoticz version: 2020beta
Post by florisi »
I'm running dashticz stable on my ubuntu server.
Wanna upgrade to v3.4.1 beta
How can I upgrade to the last beta?
Alfagek
Domoticz version: 2020.1
Re: Update from v3.3.3.1 (stable) to v3.4.1 (beta)
Post by Alfagek »
git checkout beta
git pull
florisi
Post by florisi »
Thanks, works.
But still have the problem with the Mi Flower.
Lokonli
Post by Lokonli »
Normally we are pretty quick in answering issues, but we can't address all requests within one day.
If you want to help, you are more than welcome.
Anyway, to add Mi Flower support, replace the function getExtendedBlockTypes in custom/custom.js with the following:
function getExtendedBlockTypes(blocktypes){
	blocktypes.SubType['Soil Moisture'] = {}
	blocktypes.SubType['Soil Moisture']['cb'] = {
		icon: 'fas fa-seedling',
		title: '<Name>',
		value: '<Data>',
	blocktypes.SubType['Soil Moisture']['advice'] = {
		title: '<Name>',
		value: '<Desc>',
	return blocktypes;
You should get two devices: The moisture value, and the irrigation advice.
Please confirm whether this is working, and I'll merge it in the next beta release.
florisi
Post by florisi »
Replaced custom.js with the snippet, now the devices are disappeared. (not working)
Here is my current custom.js
 //add custom javascript in here
function afterGetDevices(){
        title: '<Name>',
        value: '<Data>',
        title: '<Name>',
        value: '<Desc>',
    return blocktypes;
function getStatus_98(idx,value,device) {
    if(parseFloat(device['Data'])>1000) {
        $('div.block_98').addClass('warning');
    } else {
        $('div.block_98').removeClass('warning');
function getStatus_100(idx,value,device) {
        $('div.block_100').addClass('warning');
    } else {
        $('div.block_100').removeClass('warning');
Lokonli
Post by Lokonli »
In 3.4.1 beta the interface of the getStatus functions changed. See the following link for some examples:
https://dashticz.readthedocs.io/en/beta ... fterupdate
replace the functions with the following code block:
function getStatus_98(block) {
var device=block.device;
        block.addClass='warning';
    } else {
        block.addClass='';
florisi
Post by florisi »
thanks for the update, but still not working.
The Mi Flower doesn't appear.
Here is the custom.js again.
        title: '<Name>',
        value: '<Data>',
        title: '<Name>',
        value: '<Desc>',
    return blocktypes;
    } else {
        block.addClass='';
function getStatus_100(block) {
    } else {
        block.addClass='';
Lokonli
Post by Lokonli »
The other blocks are displayed correctly?
Can you open DevTools in Chrome by pressing F12.
Then open or refresh Dashticz.
In Devtools go to the console tab. Do you see any error?
florisi
Post by florisi »
I have this error:
TypeError: (title + value).match is not a function
    at getStatusBlock (js/blocks.js:897)
    at handleDevice (js/blocks.js:1342)
    at deviceUpdateHandler (js/blocks.js:394)
    at js/blocks.js:448
    at ListObservable.subscribe (js/domoticz-api.js:421)
    at Object._subscribe [as subscribe] (js/domoticz-api.js:342)
    at addDeviceUpdateHandler (js/blocks.js:446)
    at getBlock (js/blocks.js:307)
    at buildScreens (<anonymous>:457:29)
    at onLoad (<anonymous>:241:5)
Lokonli
Post by Lokonli »
I think I've found the issue.
Try the following in custom.js for the getExtendedBlockTypes function:
        title: '<Name>',
        value: '<Data> <Desc>',
    return blocktypes;
florisi
Post by florisi »
that's working.
The device shows:
41 cb irrigation advise.
Lokonli
Post by Lokonli »
florisi wrote: Wednesday 01 April 2020 21:18 that's working.
The device shows:
Good. Time to water the plants :)
Apparently subdevices cannot be generated from a SubType device block at the moment, but that can be changed.
Do you prefer one or two devices?
florisi
Post by florisi »
I prefer two devices if it. is not to much work.
Will check tomorrow.
Gianni
Post by Gianni »
how can i upgrade from this.
my version is 3.3.4 beta
git checkout beta
Already on 'beta'
Your branch is up to date with 'origin/beta'.
gianni@domotic:/var/www/html/homecontrol $ git pull
Already up to date.
Lokonli
Post by Lokonli »
What do you get with:
git remote -v
Gianni
Post by Gianni »
@lokonli you was faster then me :-)
was already testing
gianni@domotic:/var/www/html/homecontrol $ git remote -v
origin  https://github.com/dashticzv3/dashticz_v3 (fetch)
origin  https://github.com/dashticzv3/dashticz_v3 (push)
gianni@domotic:/var/www/html/homecontrol $ git status
On branch beta
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git checkout -- <file>..." to discard changes in working directory)
[code]
Lokonli
Post by Lokonli »
You are using my old repository...
git remote set-url origin https://github.com/Dashticz/dashticz
git pull
Gianni
Post by Gianni »
1 step + but abort error now
remote: Enumerating objects: 646, done.
remote: Counting objects: 100% (646/646), done.
remote: Compressing objects: 100% (106/106), done.
remote: Total 2610 (delta 567), reused 585 (delta 538), pack-reused 1964
Receiving objects: 100% (2610/2610), 13.66 MiB | 5.72 MiB/s, done.
Resolving deltas: 100% (1729/1729), completed with 81 local objects.
From https://github.com/Dashticz/dashticz
   68a376c..6b4374a  beta                                -> origin/beta
 * [new branch]      blocks                              -> origin/blocks
 * [new branch]      dependabot/npm_and_yarn/acorn-6.4.1 -> origin/dependabot/npm_and_yarn/acorn-6.4.1
 + 11e431f...e67ca60 master                              -> origin/master  (forced update)
 * [new tag]         v3.0.0                              -> v3.0.0
 * [new tag]         v3.0.3-beta                         -> v3.0.3-beta
 * [new tag]         v3.0.4-beta                         -> v3.0.4-beta
 * [new tag]         v3.0.5                              -> v3.0.5
 * [new tag]         v3.0.6                              -> v3.0.6
 * [new tag]         v3.0.6-beta                         -> v3.0.6-beta
 * [new tag]         v3.1.0-beta                         -> v3.1.0-beta
 * [new tag]         v3.1.1-beta                         -> v3.1.1-beta
 * [new tag]         v3.1.2                              -> v3.1.2
 * [new tag]         v3.3.2                              -> v3.3.2
 * [new tag]         v3.3.3                              -> v3.3.3
 * [new tag]         v3.3.4-beta                         -> v3.3.4-beta
 * [new tag]         v3.4.1-beta                         -> v3.4.1-beta
Updating 68a376c..6b4374a
error: Your local changes to the following files would be overwritten by merge:
        .gitignore
        Dockerfile
        Makefile
        README.md
        css/creative.css
        docs/blocks/blocks.rst
        docs/blocks/buttons.rst
        docs/blocks/domoticzblocks.rst
        docs/blocks/frames.rst
        docs/blocks/specials/calendar.rst
        docs/blocks/specials/garbage.rst
        docs/blocks/specials/news.rst
        docs/blocks/specials/publictransport.rst
        docs/blocks/specials/streamplayer.rst
        docs/blocks/specials/trafficinfo.rst
        docs/blocks/specials/tvguide.rst
        docs/blocks/specials/weather.rst
        docs/customcss/customcss.rst
        docs/customjss/customjss.rst
        docs/dashticzconfiguration.rst
        docs/develop/code.rst
        docs/develop/documentation.rst
        docs/gettingstarted/automaticinstall.rst
        docs/gettingstarted/basicdashboard.rst
        docs/gettingstarted/manualinstall.rst
        docs/index.rst
        docs/releasenotes.rst
        docs/screens.rst
        docs/tipsandtricks.rst
        index.html
        index2.html
        js/blocks.js
        js/calendar.js
        js/chromecast.js
        js/garbage.js
        js/graphs.js
        js/login.js
        js/main.js
        js/publictransport.js
        js/settings.js
        js/sonarr.js
        js/switches.js
        js/thermostat.js
        js/version.js
        js/weather_owm.js
        lang/bs_BA.json
        lang/ca_ES.json
        lang/cs_CZ.json
        lang/da_DK.json
        lang/de_DE.json
        lang/en_US.json
        lang/es_ES.json
        lang/fi_FI.json
        lang/fr_FR.json
        lang/hu_HU.json
        lang/it_IT.json
        lang/lt_LT.json
        lang/nb_NO.json
        lang/nl_NL.json
        lang/nn_NO.json
        lang/pl_PL.json
        lang/pt_PT.json
        lang/ro_RO.json
        lang/ru_RU.json
        lang/sk_SK.json
        lang/sl_SI.json
        lang/sr_RS.json
        lang/sv_SE.json
        lang/tr_TR.json
        lang/uk_UA.json
        lang/zh_CN.json
        scripts/dashticz_install.sh
        vendor/dashticz/ical/index.php
        version.txt
Please commit your changes or stash them before you merge.
error: The following untracked working tree files would be overwritten by merge:
        .babelrc
        .eslintrc.js
        .vscode/settings.json
        babel.config.js
        css/secpanel.css
        dist/0724bb8b89ab6b8b9b7df917b17be0b7.svg
        dist/57dcda6f368ea90179f75cbdae96c263.eot
        dist/5d0861781aeef6c82fda3a3076954a1b.svg
        dist/75f38a159982b6bd1704891332d95fa7.ttf
        dist/89889688147bd7575d6327160d64e760.svg
        dist/89e02bae13c9131c7468b1e729339ac1.eot
        dist/9d67fa1429375bd2a899a17eb77d0342.svg
        dist/9ec698d1a597bff5df337094b71ddaaf.ttf
        dist/assets/images/ui-icons_444444_256x240.png
        dist/assets/images/ui-icons_555555_256x240.png
        dist/assets/images/ui-icons_777620_256x240.png
        dist/assets/images/ui-icons_777777_256x240.png
        dist/assets/images/ui-icons_cc0000_256x240.png
        dist/assets/images/ui-icons_ffffff_256x240.png
        dist/bundle.js
        docs/blocks/graphs.rst
        docs/blocks/img/climate.jpg
        docs/blocks/img/climate_te_hu.jpg
        docs/blocks/img/customlabels.jpg
        docs/blocks/img/evohome.png
        docs/blocks/img/graph_buttons1.png
        docs/blocks/img/graph_buttons2.png
        docs/blocks/img/graph_buttons3.png
        docs/blocks/img/graph_buttons4.png
        docs/blocks/img/graph_debug.jpg
        docs/blocks/img/graph_groupby_day.png
        docs/blocks/img/graph_zoom_x.jpg
        docs/blocks/img/graph_zoom_x2.jpg
        docs/blocks/img/group_by_device_1.png
        docs/blocks/img/group_by_device_2.png
        docs/blocks/img/group_by_device_3.png
        docs/blocks/img/muligraph_patch4_1.png
        docs/blocks/img/muligraph_patch4_2.png
        docs/blocks/img/muligraph_patch4_3.png
        docs/blocks/img/muligraph_patch4_4.png
        docs/blocks/img/muligraph_patch4_5.png
        docs/blocks/img/multigraph3.png
        docs/blocks/img/multigraph4.png
        docs/blocks/img/multigraph5.png
        docs/blocks/img/multigraph6.png
        docs/blocks/img/multigraph_button_styling.jpg
        docs/blocks/img/multigraph_custom.png
        docs/blocks/img/multigraph_point_styling.jpg
        docs/blocks/img/multigraph_setpoints.png
        docs/blocks/img/p1.jpg
        docs/blocks/img/p1_custom.jpg
        docs/blocks/img/p1_legend.jpg
        docs/blocks/img/p1_legend_2.jpg
        docs/blocks/img/solar_1_default.jpg
        docs/blocks/img/solar_custom_legend.jpg
        docs/blocks/img/solar_default.jpg
        docs/blocks/img/solar_legend.jpg
        docs/blocks/img/solar_yellow_bar.jpg
        docs/blocks/img/water.jpg
        docs/blocks/specials/img/calendar1.jpg
        docs/blocks/specials/security_panel.rst
        docs/blocks/specials/security_panel_block.jpg
        docs/blocks/specials/security_panel_frame.jpg
        docs/customcss/specialclasses.jpg
        docs/customjs/customjs.rst
        docs/img/dashticz-websocket.gif
        docs/releasenotes/index.rst
        docs/releasenotes/releasenotes.rst
        docs/releasenotes/upgrading/upgrading.rst
        docs/releasenotes/upgrading/v320.rst
        font/Audiowide.eot
        font/Audiowide.svg
        font/Audiowide.ttf
        font/Audiowide.woff
        font/Digital.eot
        font/Digital.svg
        font/Digital.ttf
        font/Digital.woff
        img/curtainclosed.png
        img/curtainopen.png
        img/dishwasher_240px.png
        img/dishwasher_off.png
        img/dishwasher_on.png
        img/evohome.png
        img/hot_water_on.png
        img/speaker_off.png
        img/speaker_on.png
        img/tv_off.png
        js/components/blocktitle.js
        js/components/button.js
        js/components/frame.js
        js/components/graph.js
        js/components/longfonds.js
        js/components/news.js
        js/components/publictransport.js
        js/components/secpanel.js
        js/components/stationclock.js
        js/components/streamplayer.js
        js/components/traffic.js
        js/components/trafficinfo.js
        js/components/train.js
        js/components/tvguide.js
        js/dashticz.js
        js/domoticz-api.js
        package.json
        sounds/arm.aac
        sounds/arm.mp3
        sounds/arm.ogg
        sounds/disarm.aac
        sounds/disarm.mp3
        sounds/disarm.ogg
        sounds/key.aac
        sounds/key.mp3
        sounds/key.ogg
        sounds/wrongcode.aac
        sounds/wrongcode.mp3
        sounds/wrongcode.ogg
        src/functions.js
        src/index.js
        src/templateengine.js
        vendor/dashticz/ical/composer.json
        vendor/dashticz/ical/composer.lock
        vendor/dashticz/ical/ical5/SG_iCal.php
        vendor/dashticz/ical/ical5/blocks/SG_iCal_VCalendar.php
        vendor/dashticz/ical/ical5/blocks/SG_iCal_VEvent.php
        vendor/dashticz/ical/ical5/blocks/SG_iCal_VTimeZone.php
        vendor/dashticz/ical/ical5/helpers/SG_iCal_Duration.php
        vendor/dashticz/ical/ical5/helpers/SG_iCal_Factory.php
        vendor/dashticz/i
Aborting
Lokonli
Post by Lokonli »
Maybe better to start over, make a new clone from github and copy your previous CONFIG.js, custom.css and custom.js files.
Gianni
Post by Gianni »
yep did that now :lol:
but still a error with garb....... :-p(offtopic try the auto install garb still not working)
