The name org.freedesktop.PolicyKit1 was not provided [solved]
hestia
Domoticz version: 2022.1
Post by hestia »
hello
when I do:
"service domoticz start"
I have:
"Failed to start domoticz.service: The name org.freedesktop.PolicyKit1 was not provided by any .service files
See system logs and 'systemctl status domoticz.service' for details."
Don't see much in logs, perhaps I don't know which ones to look at!
I didn't tried "service domoticz stop" nor "reboot"... afraid not be able to restart!
A the present time, domoticz is running...
sancla
Re: The name org.freedesktop.PolicyKit1 was not provided
Post by sancla »
If Domoticz is already running, why do you want to start it?
Are you trying to run multiple instances?
What version are you running?
Check these howto's: https://sancla.com
hestia
Post by hestia »
Version: 4.11605
Build Hash: 7de1f368f
Compile Date: 2020-01-08 23:12:15
Usually "service domoticz restart" doesn't give an error even if domoticz is running.
My comment was to say that I didn't want to test "service domoticz stop" just to see if the issue will be solved after a stop.
I don't need to start it now, but when I want to do it, I don't want to have this issue, as I am aware of it right now. So I would like to solve this issue before having a problem!
hestia
Post by hestia »
just to do
sudo systemctl daemon-reload
sudo service  domoticz reload
sudo service  domoticz restart
sudo service  domoticz status
and it was ok
