In the Domoticz log I get the following error message everytime someone is using our entrance door:
Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!
The door lock is an IDLock 150. It has been like that since I upgraded the lock to ZWave 1.6. I assumed that it was caused by Domoticz' missing support for Open ZWave 1.6. The other day, however, I upgraded Domoticz 2020.1, which does have Open ZWave 1.6, but the error messages keep coming in the log. I have restarted the lock, but wih no luck.
Any ideas?
Snowtiger
You use and IDlock150 how does it show in Domoticz Zwave nodes? Is it correct included?
DeVille70
Re: Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!
Indeed it is. No errors, and all the configuration settings are available.
https://www.dropbox.com/s/0tw76s01yil5n ... e.JPG?dl=0
tjabas
i have an idlock 101 and i have the same problem. i have asked i a couple of other threads here but never any response.
Snowtiger
Looks correct to me - i checked the Open Zwave config branche and no changes since Oct 2019 in the XML so no updates since then - has this ever work correct in Open Zwave version 1.4?DeVille70 wrote:Indeed it is. No errors, and all the configuration settings are available.
DeVille70
The lock works the way it always did, and as far as I can tell all functionality is there. As such, the subject error message is just annoying, It started coming when I upgraded the lock's ZWave module SW to ver 1.6 a few months ago. I ignored it then, awaiting Domoticz to be upgraded with OZW 1.6, which I did yesterday, but it made no difference.
