Version 0.6.1 of the plugin is now available for download.
This update is mandatory if you are using any version of domoticz from 2020.1 onward
(updated the domoticz version check of the plugin to the new version numbering scheme implemented in domoticz on March 22, 2020).
Python plugin: Battery Level for Z-Wave Devices
- Phantom
- Domoticz version: 4.11652
Re: Python plugin: Battery Level for Z-Wave Devices
Thanks for the update
fr3sh
I think there is a bug. You asume that tipical api uri is
in the code there is
and in my case i have:
I tried to add
8080/{CAtalog} - on the port configuration in domoticz but port is only holding for a number
Please fix it
http://{IP}:{PORT}/json.htm?....
url = "http://{}:{}/json.htm?{}".format(Parameters["Address"], Parameters["Port"], parse.quote(APICall, safe="&="))
http://{IP}:{PORT}/{CALATOG}/json.htm?....
Please fix it
git pull and start working again. Thanks!Logread wrote: Tuesday 24 March 2020 9:18 Version 0.6.1 of the plugin is now available for download.
multinet
Hello
I just move to last domoticz and last plugin battery level
My zwave device are well configurated and running well.
My question is to now if battery plugin update the level (and as well the date of update on device) even if the % does not change.
Indeed my level devices have not been updated since 3 days even if each zwave are update temp for exemple every 10 min
Thank you
Thank you
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
6 sondes DS18B20
Atis
I try this plugin with 2020.2.12213-8 version. After install completing crashing domoticz.
newpond
can we use a https api call instead of using port 8080?
I still seem to be getting the following error however even using port 8080
Error: Z-Wave Batteries: Error calling 'http://192.168.1.9:8080/json.htm?type=c ... vels&idx=2
2023.1 build 15344 python ver 3.73
Logread
Not sure what you mean, but anyway the currently publicly available plugin is deprecated together with openzwave. I adapted the plungin to work with MQTT and zwave- js-ui, but I still need to push that to GitHub. May be next week when I am on vacations
