Hi Every body
I have a question, i hope that i put this question in the right topic. A while ago i have bought a raspberry pi 3, installed domoticz, but didn’t used it for a while.
I again started up today but i cannot acces domoticz on port 8080 or 443.
Through Putty I can login als PI, thats works.
Can you help me what to do, or is the best solution to install domoticz again?
Regards, Paul
Domoticz starting up after a while Topic is solved
pauluzfirst
Re: Domoticz starting up after a while
Hi Paul,
Last few days a new stable version game out of Domoticz. May I suggest, as you state the a fresh installation is an option, to do so?
If not, is the Domoticz service running?
Check these howto's: https://sancla.com
pauluzfirst
Hi Sancla,
Thank you for your help, with the use of the command sudo raspi-config within putty, I got it running again, including the newest update V2020.1
