- Spoiler: show
2020-03-25 11:48:36.942 [6fafe220] (Darksky weather Nunspeet) Rain (Regen Nunspeet) 2020-03-25 11:48:36.958 [6fafe220] Debug: SQLH UpdateValueInt Helderheid zicht Nunspeet HwID:24 DevID:0 Type:243 sType:1 nValue:0 sValue:16.1 2020-03-25 11:48:36.970 [6fafe220] subtype = Visibility Visibility = 16.1 km 2020-03-25 11:48:36.970 [6fafe220] (Darksky weather Nunspeet) General/Visibility (Helderheid zicht Nunspeet) 2020-03-25 11:48:36.986 [6fafe220] Debug: SQLH UpdateValueInt Ozone Sensor HwID:24 DevID:00000100 Type:243 sType:31 nValue:0 sValue:339.8000 2020-03-25 11:48:36.986 [6fafe220] subtype = Custom Sensor Value = 339.8 2020-03-25 11:48:36.988 [6fafe220] (Darksky weather Nunspeet) General/Custom Sensor (Ozone Sensor) 2020-03-25 11:48:37.002 [6fafe220] Debug: SQLH UpdateValueInt Cloud Cover Nunspeet HwID:24 DevID:00000001 Type:243 sType:6 nValue:0 sValue:6.00 2020-03-25 11:48:37.013 [6fafe220] subtype = Percentage Percentage = 6.00 2020-03-25 11:48:37.014 [6fafe220] (Darksky weather Nunspeet) General/Percentage (Cloud Cover Nunspeet) 2020-03-25 11:48:37.365 [74b88220] (Zigate Zigbee) Receive NACK from Overloop slaapkamer pama (5296) clusterId: 0000 2020-03-25 11:48:40.196 [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 359, Sat: 100, RGB: 16711680, CT: 3124 2020-03-25 11:48:40.197 [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 75, Hue: 359, Sat: 100, RGB: 16711680, CT: 3236 2020-03-25 11:48:40.198 [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 0, Sat: 100, RGB: 16711680, CT: 3601 2020-03-25 11:48:40.199 [6d4fe220] Debug: Yeelight::InsertUpdateSwitch colorMode: 2, Bri: 100, Hue: 358, Sat: 84, RGB: 16721711, CT: 4241 2020-03-25 11:48:42.310 [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.030;893900.000 2020-03-25 11:48:42.330 [6fafe220] subtype = kWh Instant = 0.030 Counter = 893.900 2020-03-25 11:48:42.330 [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-03-25 11:48:42.357 [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11 DevID:0000501 Type:248 sType:1 nValue:0 sValue:0.0 2020-03-25 11:48:42.377 [6fafe220] subtype = Electric Usage = 0.0 W 2020-03-25 11:48:42.377 [6fafe220] (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik) 2020-03-25 11:48:42.404 [74b88220] Debug: SQLH HandleOnOffAction: OnAction: 2020-03-25 11:48:42.405 [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.030;893900.000 2020-03-25 11:48:42.407 [74b88220] Debug: SQLH UpdateValueInt Lamp overloop slaapkamer Anna HwID:35 DevID:14b457fffe2607c9 Type:244 sType:73 nValue:1 sValue:99 2020-03-25 11:48:42.416 [6fafe220] subtype = kWh Instant = 0.030 Counter = 893.900 2020-03-25 11:48:42.417 [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-03-25 11:48:42.449 [6fafe220] Debug: SQLH UpdateValueInt Voltage HwID:11 DevID:00000501 Type:243 sType:8 nValue:0 sValue:235.400 2020-03-25 11:48:42.449 [6fafe220] subtype = Voltage Voltage = 235.400 V 2020-03-25 11:48:42.450 [6fafe220] (Zwave USB) General/Voltage (Voltage) 2020-03-25 11:48:42.484 [74b88220] Error: Domoticz(pid:5466, tid:5475('PluginMgr')) received fatal signal 11 (Segmentation fault) 2020-03-25 11:48:42.484 [74b88220] Error: siginfo address=0x155a, address=(nil) 2020-03-25 11:48:50.960 [6fafe220] Debug: SQLH UpdateValueInt Temperatuur buiten HwID:3 DevID:16385 Type:82 sType:5 nValue:0 sValue:8.8;47;1 2020-03-25 11:48:51.024 [6fafe220] subtype = TH5 - WTGR800 Sequence nbr = 0 ID = 16385 Temperature = 8.8 C Humidity = 47 % Status = Comfortable Signal level = 12 Battery = Low 2020-03-25 11:48:51.025 [6fafe220] (433Mhz RFlink Gateway) Temp + Humidity (Temperatuur buiten) 2020-03-25 11:48:51.135 [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.030;893900.000 2020-03-25 11:48:51.159 [6fafe220] subtype = kWh Instant = 0.030 Counter = 893.900 2020-03-25 11:48:51.160 [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-03-25 11:48:51.198 [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11 DevID:0000501 Type:248 sType:1 nValue:0 sValue:0.0 2020-03-25 11:48:51.210 [6fafe220] subtype = Electric Usage = 0.0 W 2020-03-25 11:48:51.210 [6fafe220] (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik) 2020-03-25 11:48:51.252 [6fafe220] Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.040;893900.000 2020-03-25 11:48:51.263 [6fafe220] subtype = kWh Instant = 0.040 Counter = 893.900 2020-03-25 11:48:51.264 [6fafe220] (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-03-25 11:48:51.296 [6fafe220] Debug: SQLH UpdateValueInt Voltage HwID:11 DevID:00000501 Type:243 sType:8 nValue:0 sValue:235.400 2020-03-25 11:48:51.296 [6fafe220] subtype = Voltage Voltage = 235.400 V 2020-03-25 11:48:51.296 [6fafe220] (Zwave USB) General/Voltage (Voltage) 2020-03-25 11:48:51.507 [74b88220] Error: Thread 4 (Thread 0x74b88220 (LWP 5475)): 2020-03-25 11:48:51.507 [74b88220] Error: #0 __waitpid (options=0, stat_loc=0x74b85e88, pid=3763) at ../sysdeps/unix/sysv/linux/waitpid.c:30 2020-03-25 11:48:51.507 [74b88220] Error: #1 __waitpid (pid=3763, stat_loc=0x74b85e88, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25 2020-03-25 11:48:51.507 [74b88220] Error: #2 0x002db8c4 in dumpstack_gdb(bool) () 2020-03-25 11:48:51.507 [74b88220] Error: #3 0x002dbe90 in signal_handler(int, siginfo_t*, void*) () 2020-03-25 11:48:51.507 [74b88220] Error: #4 <signal handler called> 2020-03-25 11:48:51.507 [74b88220] Error: #5 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50 2020-03-25 11:48:51.507 [74b88220] Error: #6 <signal handler called> 2020-03-25 11:48:51.507 [74b88220] Error: #7 0x007f346c in packet.queue () 2020-03-25 11:48:51.507 [74b88220] Error: #8 0x007f6458 in send.real_publish () 2020-03-25 11:48:51.507 [74b88220] Error: #9 0x007ee278 in mosquitto_publish () 2020-03-25 11:48:51.508 [74b88220] Error: #10 0x002bf71c in mosqdz::mosquittodz::publish(int*, char const*, int, void const*, int, bool) () 2020-03-25 11:48:51.508 [74b88220] Error: #11 0x004d9988 in MQTT::SendMessage(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) () 2020-03-25 11:48:51.508 [74b88220] Error: #12 0x004db6a0 in MQTT::SendDeviceInfo(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) () 2020-03-25 11:48:51.508 [74b88220] Error: #13 0x002bd4c8 in boost::signals2::detail::signal_impl<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*), boost::signals2::optional_last_value<void>, int, std::less<int>, boost::function<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::function<void (boost::signals2::connection const&, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::signals2::mutex>::operator()(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) () 2020-03-25 11:48:51.508 [74b88220] Error: #14 0x0064edf0 in Plugins::CDevice_update(Plugins::CDevice*, _object*, _object*) () 2020-03-25 11:48:51.508 [74b88220] Error: #15 0x75e5cd48 in _PyMethodDef_RawFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-03-25 11:48:51.508 [74b88220] Error: #16 0x75e5dca4 in _PyCFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-03-25 11:48:51.508 [74b88220] Error: #17 0x75c5d1d4 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-03-25 11:48:51.508 [74b88220] Error: #18 0x75d8f4d4 in _PyEval_EvalCodeWithName () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-03-25 11:48:51.508 [74b88220] Error: #19 0x75e5d340 in _PyFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-03-25 11:48:51.508 [74b88220] Error: #20 0x75c5a950 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-03-25 11:48:51.508 [74b88220] Error: #21 0x75c5edd4 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so ______________________________________________________ 2020-02-23 06:39:34.321 Debug: SQLH UpdateValueInt Temperatuur buiten HwID:3 DevID:16385 Type:82 sType:5 nValue:0 sValue:7.0;83;3 2020-02-23 06:39:34.724 (433Mhz RFlink Gateway) Temp + Humidity (Temperatuur buiten) 2020-02-23 06:39:39.403 Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.050;766100.000 2020-02-23 06:39:39.470 Debug: SQLH UpdateValueInt PiMonitor - GPU temperature HwID:10 DevID:000A0002 Type:243 sType:31 nValue:54 sValue:54.8 2020-02-23 06:39:40.675 (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-02-23 06:39:41.049 Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11 DevID:0000501 Type:248 sType:1 nValue:0 sValue:0.0 2020-02-23 06:39:41.115 (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik) 2020-02-23 06:39:41.129 Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.000;766100.000 2020-02-23 06:39:41.146 (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-02-23 06:39:41.213 Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11 DevID:0000501 Type:248 sType:1 nValue:0 sValue:0.0 2020-02-23 06:39:41.223 (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik) 2020-02-23 06:39:41.224 Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.000;766100.000 2020-02-23 06:39:41.235 (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-02-23 06:39:41.236 Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11 DevID:0000501 Type:248 sType:1 nValue:0 sValue:0.0 2020-02-23 06:39:41.246 (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik) 2020-02-23 06:39:41.247 Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:0.000;766100.000 2020-02-23 06:39:41.258 (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-02-23 06:39:42.452 Error: Domoticz(pid:4700, tid:4711('PluginMgr')) received fatal signal 11 (Segmentation fault) 2020-02-23 06:39:42.516 Error: siginfo address=0x125c, address=(nil) 2020-02-23 06:39:46.341 Debug: SQLH UpdateValueInt Temperature HwID:11 DevID:1282 Type:80 sType:5 nValue:0 sValue:23.8 2020-02-23 06:39:52.348 Error: EventSystem: Warning!, lua script /home/pi/domoticz/dzVents/runtime/dzVents.lua has been running for more than 10 seconds 2020-02-23 06:39:55.052 (Zwave USB) Temp (Temperature) 2020-02-23 06:39:57.729 Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11 DevID:0000501 Type:242 sType:1 nValue:0 sValue:23.50 2020-02-23 06:40:22.485 (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling) 2020-02-23 06:40:30.463 Debug: SQLH UpdateValueInt Ingestelde temperatuur Nefit Easy HwID:2 DevID:0010101 Type:242 sType:1 nValue:0 sValue:17.00 2020-02-23 06:40:45.316 (Nefit Easy Thermostaat ) Thermostat (Ingestelde temperatuur Nefit Easy) 2020-02-23 06:40:45.316 Error: Failed to start gdb, will use backtrace() for printing stack frame 2020-02-23 06:40:47.333 Debug: SQLH UpdateValueInt Temperatuur kamer HwID:2 DevID:1 Type:80 sType:5 nValue:0 sValue:18.0 2020-02-23 06:40:48.194 Error: #0 /home/pi/domoticz/domoticz() [0x2cd824] 2020-02-23 06:40:48.201 Error: #1 /home/pi/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x1f8 [0x2ce1e0] 2020-02-23 06:40:48.201 Error: #2 /lib/arm-linux-gnueabihf/libc.so.6 : __default_rt_sa_restorer + 0 [0x76a14130] 2020-02-23 07:07:12.376 Status: Domoticz V4.11674 (c)2012-2020 GizMoCuz 2020-02-23 07:07:12.406 Status: Build Hash: 91c3475ac, Date: 2020-02-09 10:00:09 2020-02-23 07:07:12.407 Status: Startup Path: /home/pi/domoticz/ 2020-02-23 07:07:21.384 Sunrise: 07:37:00 SunSet: 18:03:00 2020-02-23 07:07:21.385 Day length: 10:27:00 Sun at south: 12:50:00 ____________________________________________________________- 2020-02-23 21:34:32.164 Debug: SQLH UpdateValueInt Ingestelde temperatuur Nefit Easy HwID:2 DevID:0010101 Type:242 sType:1 nValue:0 sValue:19.00 2020-02-23 21:34:32.184 (Nefit Easy Thermostaat ) Thermostat (Ingestelde temperatuur Nefit Easy) 2020-02-23 21:34:32.211 Debug: SQLH UpdateValueInt Temperatuur kamer HwID:2 DevID:1 Type:80 sType:5 nValue:0 sValue:19.1 2020-02-23 21:34:32.230 (Nefit Easy Thermostaat ) Temp (Temperatuur kamer) 2020-02-23 21:34:32.352 Debug: SQLH UpdateValueInt Flow Temperature HwID:2 DevID:3 Type:80 sType:5 nValue:0 sValue:41.0 2020-02-23 21:34:32.352 (Nefit Easy Thermostaat ) Temp (Flow Temperature) 2020-02-23 21:34:34.633 Debug: SQLH UpdateValueInt Cooling HwID:11 DevID:0000502 Type:242 sType:1 nValue:0 sValue:21.00 2020-02-23 21:34:34.634 (Zwave USB) Thermostat (Cooling) 2020-02-23 21:34:34.693 Debug: SQLH UpdateValueInt Cooling HwID:11 DevID:0000502 Type:242 sType:1 nValue:0 sValue:21.00 2020-02-23 21:34:34.695 (Zwave USB) Thermostat (Cooling) 2020-02-23 21:34:44.685 Debug: SQLH UpdateValueInt PiMonitor - CPU usage HwID:10 DevID:000A0004 Type:243 sType:31 nValue:4 sValue:4.4 2020-02-23 21:34:44.688 Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:748.630;768400.000 2020-02-23 21:34:44.708 (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-02-23 21:34:44.730 Error: Domoticz(pid:2161, tid:2215('PluginMgr')) received fatal signal 11 (Segmentation fault) 2020-02-23 21:34:44.730 Error: siginfo address=0x871, address=(nil) 2020-02-23 21:34:44.822 Debug: SQLH UpdateValueInt Vloerverwarming badkamer stroomverbruik HwID:11 DevID:0000501 Type:248 sType:1 nValue:0 sValue:748.3 2020-02-23 21:34:44.841 (Zwave USB) Usage (Vloerverwarming badkamer stroomverbruik) 2020-02-23 21:34:44.854 Debug: SQLH UpdateValueInt Vloerverwarming badkamer kWh Meter HwID:11 DevID:00000501 Type:243 sType:29 nValue:0 sValue:748.260;768400.000 2020-02-23 21:34:44.866 (Zwave USB) General/kWh (Vloerverwarming badkamer kWh Meter) 2020-02-23 21:34:44.977 Debug: SQLH UpdateValueInt Voltage HwID:11 DevID:00000501 Type:243 sType:8 nValue:0 sValue:230.500 2020-02-23 21:34:44.977 (Zwave USB) General/Voltage (Voltage) 2020-02-23 21:34:51.145 Error: Thread 4 (Thread 0x74b6e220 (LWP 2215)): 2020-02-23 21:34:51.146 Error: #0 __waitpid (options=0, stat_loc=0x74b6c2d0, pid=23733) at ../sysdeps/unix/sysv/linux/waitpid.c:30 2020-02-23 21:34:51.146 Error: #1 __waitpid (pid=23733, stat_loc=0x74b6c2d0, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25 2020-02-23 21:34:51.146 Error: #2 0x002cdbcc in dumpstack_gdb(bool) () 2020-02-23 21:34:51.146 Error: #3 0x002ce198 in signal_handler(int, siginfo_t*, void*) () 2020-02-23 21:34:51.146 Error: #4 <signal handler called> 2020-02-23 21:34:51.146 Error: #5 raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50 2020-02-23 21:34:51.146 Error: #6 <signal handler called> 2020-02-23 21:34:51.146 Error: #7 0x007d4e04 in packet.queue () 2020-02-23 21:34:51.146 Error: #8 0x007d7df0 in send.real_publish () 2020-02-23 21:34:51.146 Error: #9 0x007cfc14 in mosquitto_publish () 2020-02-23 21:34:51.146 Error: #10 0x002b46dc in mosqdz::mosquittodz::publish(int*, char const*, int, void const*, int, bool) () 2020-02-23 21:34:51.146 Error: #11 0x004c16f0 in MQTT::SendMessage(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) () 2020-02-23 21:34:51.146 Error: #12 0x004c3184 in MQTT::SendDeviceInfo(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) () 2020-02-23 21:34:51.146 Error: #13 0x002b379c in boost::signals2::detail::signal_impl<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*), boost::signals2::optional_last_value<void>, int, std::less<int>, boost::function<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::function<void (boost::signals2::connection const&, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::signals2::mutex>::operator()(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) () 2020-02-23 21:34:51.146 Error: #14 0x006330c8 in Plugins::CDevice_update(Plugins::CDevice*, _object*, _object*) () 2020-02-23 21:34:51.146 Error: #15 0x75e42d48 in _PyMethodDef_RawFastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-02-23 21:34:51.146 Error: #16 0x75e43ca4 in _PyCFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-02-23 21:34:51.146 Error: #17 0x75c431d4 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-02-23 21:34:51.146 Error: #18 0x75d754d4 in _PyEval_EvalCodeWithName () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-02-23 21:34:51.146 Error: #19 0x75e43340 in _PyFunction_FastCallKeywords () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-02-23 21:34:51.146 Error: #20 0x75c40950 in _PyEval_EvalFrameDefault () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so 2020-02-23 21:34:51.146 Error: #21 0x75c44dd4 in ?? () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so ____________________________________________________________- 2020-03-02 01:23:23.024 Debug: SQLH UpdateValueInt Temperature HwID:11 DevID:1282 Type:80 sType:5 nValue:0 sValue:22.1 2020-03-02 01:23:23.044 (Zwave USB) Temp (Temperature) 2020-03-02 01:23:27.056 Debug: SQLH UpdateValueInt Xiron HwID:3 DevID:20482 Type:82 sType:5 nValue:0 sValue:18.2;48;1 2020-03-02 01:23:27.056 (433Mhz RFlink Gateway) Temp + Humidity (Xiron) 2020-03-02 01:23:32.074 Debug: SQLH UpdateValueInt Ingestelde temperatuur Nefit Easy HwID:2 DevID:0010101 Type:242 sType:1 nValue:0 sValue:17.00 2020-03-02 01:23:32.093 (Nefit Easy Thermostaat ) Thermostat (Ingestelde temperatuur Nefit Easy) 2020-03-02 01:23:32.096 Debug: SQLH UpdateValueInt Temperatuur kamer HwID:2 DevID:1 Type:80 sType:5 nValue:0 sValue:18.7 2020-03-02 01:23:32.133 (Nefit Easy Thermostaat ) Temp (Temperatuur kamer) 2020-03-02 01:23:32.262 Debug: SQLH UpdateValueInt Flow Temperature HwID:2 DevID:3 Type:80 sType:5 nValue:0 sValue:52.0 2020-03-02 01:23:32.262 (Nefit Easy Thermostaat ) Temp (Flow Temperature) 2020-03-02 01:23:33.023 Debug: SQLH UpdateValueInt PiMonitor - CPU temperature HwID:10 DevID:000A0001 Type:243 sType:31 nValue:50 sValue:50.5 2020-03-02 01:23:33.038 Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11 DevID:0000501 Type:242 sType:1 nValue:0 sValue:21.00 2020-03-02 01:23:33.064 (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling) 2020-03-02 01:23:33.081 Error: Domoticz(pid:27323, tid:27329('PluginMgr')) received fatal signal 11 (Segmentation fault) 2020-03-02 01:23:33.081 Error: siginfo address=0x6abb, address=(nil) 2020-03-02 01:23:33.099 Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11 DevID:0000501 Type:242 sType:1 nValue:0 sValue:21.00 2020-03-02 01:23:33.111 (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling) 2020-03-02 01:23:33.127 Debug: SQLH UpdateValueInt Vloerverwarming badkamer temp. instelling HwID:11 DevID:0000501 Type:242 sType:1 nValue:0 sValue:21.00 2020-03-02 01:23:33.137 (Zwave USB) Thermostat (Vloerverwarming badkamer temp. instelling) 2020-03-02 02:20:29.128 Error: MQTT: disconnected, restarting (rc=7) 2020-03-02 02:20:29.128 Status: Schedule item started! Name: Vloerverwarming badkamer temp. instelling, Type: On Time, ThermostatID: 403, Time: 2020-03-02 02:20:28 2020-03-02 02:20:29.128 Error: mainworker seems to have ended or hung unexpectedly (last update 3420.000000 seconds ago) 2020-03-02 02:20:29.361 Debug: SQLH: Do Task ItemType:4 Cmd:Off Value: 2020-03-02 02:20:30.196 Error: Domoticz(27323) is exiting due to watchdog triggered... 2020-03-02 02:20:30.220 Error: Failed to start gdb, will use backtrace() for printing stack frame 2020-03-02 02:20:32.568 Error: #0 /home/pi/domoticz/domoticz() [0x2cd824] 2020-03-02 02:20:32.798 Error: #1 /home/pi/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x1f8 [0x2ce1e0] 2020-03-02 02:20:32.798 Error: #2 /lib/arm-linux-gnueabihf/libc.so.6 : __default_rt_sa_restorer + 0 [0x76991130] ____________________________________________________________-
Crash after voltage report Zwave floor thermostat
Geitje
I keep getting a crash about every week or so. If I check the logs it must have something to do with my Zwave Heat-it floor thermostat. Every crash it is after that reported operating voltage. See the collected last lines of crashlog below. Anyone has an idea how to solve this?
- Spoiler: show
Zwave, Zigate, RFlink etc.
